I just install my 5.3 engine into my 68 suburban, but I notice that on the passenger side the oil pan is rubbing just a bit into the cross member, I install the CPP engine mounts in the front most holes, is that where is supposed to go, or do I need to installed them in the back holes. If I installed them inthe back holes, do I need to drill a hole for the bolt that goes into the cross member. As it is right now, with the motor mounts in the front the tranny support from CPP does not line up with the holes from the chassis.
I am attaching 2 pictures ![]() ![]() |
A guy with a truck
Re: CPP Motor Mounts and Tranny support question
Move it back. You may have to drill for the trans...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
![]() ![]() Join Date: Oct 2011
Put mine the the back holes
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
66chevymax, that is what I am thinking of doing, I will just have to drill a hole in the cross member, since it does not have one there.
That is correct. Take good measurements before you do. That bottom slides in at more of an angle than you think.
![]() Join Date: Aug 2004
I would use the ECE mounts instead of the CPP mounts. THey allow you to move the perches from the front to the back without drilling anything. I didnt like the CPP mounts but that was me. I also used the CPP trans mount and liked it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
well I drill another hole in the cross member and it works, but now have an issue with the cpp tranny support, if I alignes the support the holes in the tranny mount do not line up, so I have to install the support at a littl angle, the tranny is centered but it is at an angle, so I am gone have to look into it, here some pics.
I just re-drilled my trans mount holes.
I will have to do the same but I'm holding off until I have headers that fit.
The CPP mounts wouldnt allow me to use one set of headers I had, so that is why I went with the ECE perches. they will fit front or back mounting holes. I had to trim my top frame rail but 68-72 wont have to IIRC
