01-22-2012, 11:21 PM | #1 |
C 4 vett suspension in AD trucks
Need info ...on one side of the shop I have a 96 vette..
On the other a 53 AD 3100.... I know Im not the first.. Pics,Pros<Cons...Kits ...patterns .. TKS KC
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
01-23-2012, 05:32 AM | #2 |
Re: C 4 vett suspension in AD trucks
give ''Flatout engineering a call - donny should have the answers ya need - good luck
01-24-2012, 01:49 AM | #3 |
Check these guys out, Progressive Automotive. I got my front cross member and many other item. Worth the look. http://www.progressiveautomotive.com/sweet.htm
Here's my little project, 1954 5 window, 1989 C4 IRS and IFS, tons of fun......http://www.67-72chevytrucks.com/vboa...d.php?t=419646 Last edited by Deabt54; 01-24-2012 at 01:55 AM. |
01-24-2012, 01:59 PM | #4 |
Check out my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=435302 I have not found many instances of people actaully installing the kits. I have not done it myself yet either. There are a number of things that I dont like about my flat out parts, but on the other hand they are pretty nice pieces. Progressive makes you replace the whole rear frame to put on the C4 rear where Flat out you just weld on brackets, Never did figure out the big difference but went with flat out because of the way theirs works. |
01-24-2012, 07:44 PM | #5 |
I am in the middle of doing the front flat out c4. The instructions leave a lot to be disired, a pain in the butt, but I think it will turn out pretty nice.
01-24-2012, 11:56 PM | #6 |
i used flat outs system also - the instructions were not that bad . and yes it does turn out very nice . -am using coilovers instead of the leaf - i wonder if there is a way to lower the whole rear end w/o c notching the frame ?
i just dont know if there is - anyone know ? |
01-25-2012, 04:02 PM | #7 | |
01-26-2012, 08:42 PM | #8 | |
TKS KC Posted via Mobile Device
01-27-2012, 07:46 PM | #9 |
01-26-2012, 08:59 PM | #10 | |
01-26-2012, 09:58 PM | #11 |
48 GMC BURB, we are going to need a build thread when you start. I can not wait to see it with the vette underpinnings.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
01-29-2012, 01:22 PM | #12 |
duwem
Yes i installed the flat out kit .and yes it was a little bit of a pain but all things fit ;i had the exact same issue as you did - i just loose fit everyhing and jostled all the pieces in -eventually it all fit then after tighting it all up; it all fell into place . i am using coilovers and honestly it looks and feels real tight .i am v ery happy with the outcome . i am just wonderin; about lowering it w/o c notching the frame but i havent found the way to do that yet - still wrkin on puttin up some picts . do you have any picts of your install? my kit is installed on a 57 how bout yours? |
01-29-2012, 08:52 PM | #13 |
mine is a 50, so lot wider rear frame than yours.
Any pictures of the install? |
01-29-2012, 09:13 PM | #14 |
duwem
workin on gittin' picts. up |
01-30-2012, 09:39 PM | #15 |
I just got done putting a 90 C4 rear under my 49. I left the leaf spring in and haven't gotten around to putting on the sway bar. I don't think it needs it. It feels very planted, and doesnt roll at all. It fits very well except I had to use 3/4" spacers to get my 15" ralley wheels to clear the rear calipers. After researching for ever, It always seemed like the guys trying to sell me something said I needed coils, or i needed a bracket kit, or whatever. I went and purchased about $60 worth of steel plate and got out the cardboard, and started making templates to get things where I wanted them. I'll try to get some pictures of the process and finished product. If you have a sawzall and a small mig, you can fix anything. lol
01-31-2012, 12:29 PM | #16 | |
I'm thinking the same thing. The rear looks stright forwad (with enough help from those that have gone before) What is your ride heigth with the leaf ?
Did you use the toqure arm ? Pix would help a lot. TKS KC Quote:
02-01-2012, 05:42 PM | #17 |
Here's mine from a couple of years ago.
http://67-72chevytrucks.com/vboard/s...49#post3871449 |
