I know most chevy V8s its 1-8-4-3-6-5-7-2, but would it give it more power then the firing order of say 1-2-3-4-5-6-7-8?
Re: Does Changing Firing Order make more Power?
The engine couldn't run like that. The only thing you can do is a 4-7 swap with a 4-7 swap cam
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Canadian Trucker
no, and running it at 1-2-3-4-5-6-7-8 would distroy your engine. It would vibrate like an old tractor. The firing order is designed to limit the engines vibrations, and the cam shaft is designed to run 1-8-4-3-6-5-7-2.
![]() 2020 Silverado Trail Boss - 6.2/10spd |
the 4/7 swap is to make it smoother, it is what the ls engines run on (i think)
#5 | |
chevy runs deep
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
I don't think it would even run.
#7 | |
The LS is a 4-3/7-2 swap to make the engine run smother. LS firing order is 1-8-7-2-6-5-4-3. This is the one racers should do to get the cylinders to not fire sequential. If you renumber a Ford 351 (or all later Ford V8s) cylinders to the same way GM does it, you will see that the firing order is the same (so Ford got it right....ouch that hurts to say). 1-8-4-3-6-5-7-2 STD most V8's 1-8-7-3-6-5-4-2 Swaped 4 and 7 1-8-7-2-6-5-4-3 LS V8s
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
Just here to tinker
![]() Join Date: Jun 2008
I agree with all above, swapping the firing order around will either get you nothing or a lot of trouble. Do not do it. Camshafts and crankshafts are made for a specific firing order and if a spark comes along when a cylinder isn't expecting it....trouble.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#9 | |
GM Addicted
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#10 | ||
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
All questions deserve an answer that is why we are a community. Belittling someone and acting like a superior fool is not beneficial to the community and is not acceptable. If you wanna act that way take it somewhere that is less inviting or friendly. That is the "truth" of how we do things around here.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
I don't see anything wrong w/the original question. A guy should be able to reach out & ask his peers a question w/o being ridiculed. I didn't know about the 4/7 cam swap tech stuff until I learned about it (years ago). You gotta' learn somehow. I never wondered if GM's sbc/bbc firing order could possibly be 'better' but apparently the OP was thinking more outside the box than me & did question it. Kudos to him.
It can be frustrating when a guy asks a question over & over getting different responses yet he keeps asking until someone tells him what he wanted to hear all along even though other answers were better/correct. I always try to research info before asking something that I might think to myself "WTF was I thinking when I asked" type questions ![]() ![]()
#12 | |
![]() ![]() ![]() Now I want to meet your friends!! Posted via Mobile Device
#13 | |
#14 | ||
Incorrect sir because you chose to ignore the next sentence that I wrote...
1 5 2 1 3 6 4 2 5 7 6 3 7 8 8 4 1-8-7-2-6-5-4-3 LS/LQ Firing order 1-3-7-2-6-5-4-8 Ford 351 Firing order Now if you start both engine on the same cylinder the Ford Firing order becomes 5-4-8-1-3-7-2-6 Oh looky it is the same sequence as the LS. BTW that diagram does not give the whole issue, you must go throught the whole firing order not just half.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 01-25-2012 at 11:35 AM. |
#15 |
The person that put this thread up was not stupid, or dumb. He was ignorant. Ignorant means= lacking knowledge, information,or awareness about something in particular. The person that said he was stupid is not stupid. He is ignorant. He is also a mean person. People who dis respect people should be kicked off the site.
#16 | |
#17 | |
A little know fact is that the Cadillac 472-500-425-368 use the LS firing order. The Cadillac 472 was introduced in 1968. The Ford 351W was introduced in 1969. GM used the firing order before Ford did. I've also read that the head design of the LS motor is loosely based on the Cadillac V8 as well. GM actually did get it right!
1977 GMC Sierra Grande |
#18 |
Believe it or not firing order can be changed. Not to the 1 2 3 4 5 6 7 8 but it can be changed. I.e. marine engines. There are several modifications to marine engines one of which includes a change in firing order and the direction of which the motor is turning. I also dabled in Fords. I put a 351 windsor cam in a 302. It all works but the firing order is different between the two motors. Really pissed of the next mechanic that worked on the motor too
#19 |
Arrived on a Pale Horse
It won't run long if it even starts. Impossible, I believe. I've never heard of it being done.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#20 |
#21 |
Big Gulps Huh? Whelp...
edited by staff.
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
#22 |
the 4-7 swap only makes more hp in high rpms
#23 |
I see how it is....this is an acceptable response but mine get's me a "warning" from one of the mods....must have to be one of the boys on here or something...
A stupid question deserves a stupid response. ![]()
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
#24 | |
#25 |
Catchy title goes here..
![]() Join Date: Mar 2002
if you see an issue use the report a post feature... please check the attitude while you are away
