![]() Join Date: Jan 2012
Fuel filler neck grommet
Holly cow! – that grommet for the cab and fuel filler neck is a pain to install. I got it done but there has to be a secret to an easier installation. I used a soapy water solution and some dental pick style tools to pull the grommet in from the back side. It turned out good but man it was more difficult than I expected. Anyone care to share their installation secrets?
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
Re: Fuel filler neck grommet
Subcribed !
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Florida Edition
![]() ![]() Join Date: Oct 2010
I put mine in from the outside, soaped it up, and taped up a flat blade screwdriver. After I got it started I took a prybar wrapped in a towel and a baggie, slipped it down the neck and slowly, carefully wiggled the neck around as I pushed on the grommet with the screwdriver. Worked like a charm and only took a couple of minutes.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Active Member
![]() Join Date: Jul 2007
I've replaced mine at least 3-4 times in my two trucks. First couple of times it was a pain but basically did it like everyone by lubing it with silicone oil and pushing it in from the outside.
I also did it a couple of times from the inside while I had the tank out for cleaning. It seemed easier that way. First time I pushed it outward from the inside and the second time I installed it in the opening and lubed the neck of the tank and pushed it through. Bottom line, take your time, use plenty of lube and don't use sharp objects. |
I'm not trying to be dirty and this is the only picture I could find, but I just recently put the fuel tank back into my truck and I used this stuff. I put the fuel tank in first, then put the grommet in. The filler neck was slightly off center, and I had a hard time with the tighter side, but all in all it only took about 5 minutes. It's been raining good lately, and it doesn't seem to leak.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I remove the tank, install the grommet, lube the gas filler neck and then push the tank back through the installed grommet. I have also heard of some guys roping it in like a windshield. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I have only done one. I put I put the collar in a pot with water and boiled it. I slipped it right on the neck with gloves on, And it didn't take to much effort as I recall. (that was twenty years ago!) And it was an oem collar. cheers, Pat
#8 | |
If I ever have to do it again I'll definitely try this! |
#9 | |
Posted via Mobile Device |
Active Member
I've had good luck with soaking it in warm soapy water when putting it on from the outside.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
I have changed mine several times because they keep cracking after a month or two, I don't mean to hijack but has anyone found a supplier that sells a good grommet for a 72GMC? I have bought them from Classic Parts, LMC and one more that escapes me right now. Each of them sent me a free replacement but they all cracked as well. It's getting kind of old replacing them all the time. The last one I installed leaves a black streak down the cab corner every time it rains or snows.
Posted via Mobile Device Posted via Mobile Device |
![]() Join Date: Jan 2001
I used K-Y...don't laugh. I really did
![]() Gotta use it on something! |
Active Member
Try Classic Heartbeat. Mine has gone through a dry, hot Texas summer and still no cracks and black smudges.
#15 |
454 MAKES IT ROAR
Lube for "intimate contact"...it must be Truck love.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#16 |
#17 |
454 MAKES IT ROAR
Now there's an English saying...how'd that get over there.
![]() I've often wanted to use it, but assumed nobody would get it, or would think I had an unhealthy interest K9 Testicles ![]() I have used Vaseline/Petroleum Jelly, and with very little effort they slip right on.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 01-27-2012 at 06:11 AM. |
#18 |
Active Member
[QUOTE=eightbanger;5147317]...I've often wanted to use it, but assumed nobody would get it, or would think I had an unhealthy interest K Testicles
![]() I see your point. I googled the meaning. ![]() |
#19 |
Gotta love them Brits!
#20 |
3m silicone paste on the grommet and push and twist 180 no problem. The silicone is also used to protect rubber and my grommet looks new after 7 years.
Fuzzy |
#21 |
I bought a original GM one (came in a GM bag)from Wes a few weeks back, couldnt have been easier to install.
#22 |
Great feedback!
I never knew the slippery stuff or ky jelly had other uses – LMAO. I think I might have a difficult time explaining that one to my wife. I will definitely keep these in mind when I do my next one. My 72 4x4 will need to be replaced (as well as many other items) when I start her restoration. Thanks!
#23 |
2WD Jimmy
![]() Join Date: Mar 2005
Take it to dinner first, then some Barry White.
