01-26-2012, 02:00 PM | #1 |
buying bagged truck looking for advice
Hi every one
I came a cross a bagged 96 gmc (i know i'm in the 87 section but theirs more action here) its a simple setup 4 bags 2 link with a pan bar in the rear a switch to control the front and one for the rear engine driven compressor and a 10 gallon tank c notch rear frame never messed with air bags before so dont know whats good or bad? what should be looked at or watched out for? |
01-27-2012, 12:56 AM | #2 |
Re: buying bagged truck looking for advice
any and all welds that where made, and you will almost have to drive it to make sure the rear is stable and doesnt wooble or shake. look at the bolts for the trailing arms and the panhard bar and make sure there not grinding the bolts there should be bushings..if the relocated the shocks make sure there traveling straight and there not bottoming out or bending any brackets(same goes for the front). make sure the panhard and trailing arms arnt rubbing against the frame when airing up or down.....ask what grade of bolts were used look foranything rubbing brakelines,airlines....look at the quality of workmenship......a set of bags you can for around 200 250....if you want to change to elec compressores and differant tanks in the future thats not very hard. up front does it have factory control arms or after market ones made for bags........we need pictures
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
01-27-2012, 02:24 AM | #3 |
I would pass just because its a 2 link those are hard to keep the pinion angles right.And the 2 link is the cheapest way to bag the rear so the rest of it is probably done cheap too.
01-27-2012, 11:50 AM | #4 |
thanks the the tips, I bought it last night
I posted in the other section http://67-72chevytrucks.com/vboard/s...d.php?t=505707 I'm sure i'll have more questions for you guys! thanks |
01-27-2012, 12:12 PM | #5 |
Happy to be here
I moved this to the Suspension Forum for better results. Post pics of it once you have time.
