Old 01-28-2012, 12:18 AM   #1
purzell
purzell's Avatar
When to panic about white smoke
So I haven't had much success getting the truck to run, what with waiting for carb adapters, fixing vacuum leak, not having timing quite right while dealing with that stuff. Today I finally got the carb back on and while cranking, got it to run, lots of white smoke, but I didn't notice a sweet smell as some describe online. Of course, then the starter quit and I couldn't restart it anyhow.
This truck sat since 2008 before I got it. I just want to make sure that after changing out the fluids and replacing the starter and coil (next in line on Friday) I'm not going to blow up the motor, based on the white smoke being really bad news.
Is it unusual that a motor that's sat for five years will blow out some smoke before getting tuned up? Or is it likely to be one of the horrible scenarios: cracked something, valves, coolant in oil, etc...
Is it time to learn to rebuild a motor? It's the 351v6 in my '66 GMC.
purzell is offline   Reply With Quote
Old 01-28-2012, 12:36 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: When to panic about white smoke
Are you running an automatic...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-28-2012, 12:43 AM   #3
purzell
purzell's Avatar
Sorry, manual tranny.
Old 01-28-2012, 12:45 AM   #4
Rich 5150 69
Run it for while and see if it clears up...
Old 01-28-2012, 12:47 AM   #5
purzell
purzell's Avatar
OK, that's what I wanted to hear. That if I run it there's not likely to be a huge bang and a big hole appears in the motor.
Out of curiosity, and because I am a complete noob, why does a manual vs. auto matter? Thanks.
Old 01-28-2012, 01:25 AM   #6
oem4me
White smoke in an automatic can be as simple as a little hole inside your auto trans vacuum modulator valve. One sip of tranny fluid into the combustion chamber and you have an instant batmobile quality smokescreen. that's a $20 fix. Sorry, it's not your problem.
Old 01-28-2012, 12:48 AM   #7
72lb4x4
White smoke is steam meaning coolant. A few minutes of this is bad, but in winter, people always post in panic and its nothing.
Blue smoke is oil and its getting past the valve guides or rings.
Black means too much gas and you're running rich. Look at the carb.
72lb4x4 is offline   Reply With Quote
Old 01-28-2012, 12:55 AM   #8
purzell
purzell's Avatar
It's white, for sure. But I can't keep it running long enough to see if it lets up. There's just ALOT of it so I wanted to make sure it's ok to keep trying to run it rather than really screw it up.
Thanks guys.
Old 01-28-2012, 01:12 AM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Oil smoke is usually blue but can also appear white. The main thing is to make sure you check the oil level frequently to make sure nothing is broken and drinking the oil. The white smoke could also indicate somebody tried to prep the engine for a long nap by pouring some type of lubricant or preservative down the spark plug holes, and it needs to burn out before it clears up.
Old 01-28-2012, 01:29 AM   #10
joedoh
joedoh's Avatar
I vote its oil, likely all your carb work has filled the crankcase with gas running past the rings and is thinning the oil. had a truck do this once and changed the oil and cleaned the plugs, after a couple miles it was fine.
to see if this is the problem, the test is easy. pull the dipstock and see if it smells like gas (a LOT like gas) and if the oil is really thin. if so change the oil and run it a good while.
Old 01-28-2012, 01:43 AM   #11
72lb4x4
Change the oil.
Turn the engine w/ a wrench.
rebuild the carb
Spray B12 or carbcleaner in the ..... carb
An engine that sat for years in today's time frame with the bad gas we have
Old 01-28-2012, 08:37 AM   #12
skidpan
I just worked on a caddy(fuel injected) that was dumping a boat load of fuel into the engine due to a bad objectors, and I was getting snow white smoke out of the exhaust. I was worried about a blown head dumping coolant, cause it, but if you put your hand in the smoke it smelled as if you dumped it into a bucket of gas
skidpan is offline   Reply With Quote
Old 01-28-2012, 08:28 PM   #13
purzell
purzell's Avatar
Joedoh, I think you called it. The oil smells like gas and is thin. I'm going to change it out and clean the plugs, thinking 20W50, and see how that looks. So far fortunately I'm not seeing any indication of coolant in the oil or smell of coolant in the exhaust.
Old 01-28-2012, 09:27 PM   #14
Big Fenders
If I remember right if a blown head gasket is suspected you would see bubbles in your radiator coolant. Remove radiator when cool and warm up engine and look for bubbles....hopefully not.
Bob
Big Fenders is offline   Reply With Quote
Old 04-30-2017, 02:02 PM   #15
RANDY COX
RANDY COX's Avatar
x2^^ what Capt.Fab said...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
