Old 01-28-2012, 02:18 AM   #1
71SRV5VR
70 Exhaust Manifold for 350
I have a question regarding exhaust manifolds. I have a very original 1971 Chevy C-10 truck, short bed, 350 5.7 lit. 4 bbl. According to date codes, the engine was built in early Spring of 1970. The right manifold number/marking is: 3905364 RH-11 GM...the left is: 3989055 LH-21GM.
Anyway, it appears that the RH manifold was once A.I.R. equipped as it's obvious that that someone removed the device (as was common for more horsepower). I would like to replace my original RH manifold with a vintage non-A.I.R. manifold corresponding to the specs of the engine.
Does anyone by chance know the number of this part? Also, would you happen to know of a person who specializes in vintage exhaust manifolds for Chevy's of that era?
Any help/advice would be greatly appreciated!
71SRV5VR is offline   Reply With Quote
Old 01-28-2012, 02:41 AM   #2
70cst
70cst's Avatar
Re: 70 Exhaust Manifold for 350
First of all 71SRV5VR ...
to your new 67-72 internet family and from Ohio....
I don't have an answer but I am sure someone will chime in soon.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-28-2012, 11:06 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Welcome from New Mexico!
You can pick these up used if you search the parts boards, craigs-list. etc.
You also can get some new ones also.
Not sure if you have (or are using) the heat sheilds to protect the plug wire boots (you can also get these new if you need them).
Here's some links for you.
http://www.castheads.com/log_systems.php#manifolds
^This one has the original 45* angle back. I like this site because they offer the adaptors if you want to go with 2.5 in exhaust. (I ultimately used Pypes SS down pipes instead)
http://www.manestruckparts.com/store...TOKEN=44483269
^They have New & Used, plust the straight down models for the 4x4 models- don't think they are corvette 2.5's though.
http://www.speedwaymotors.com/Tru-Ra...olds,5425.html
^ Stainless steel rams here + 2.5 collectors!
http://www.castheads.com/corvette_systems.php
^Link to Corvette 2.5 rams
This should get you going....
Vaya con Dios.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
