Old 01-28-2012, 09:06 PM   #1
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
HUBCAP SPECS for 8 lug wheels
Just wondering the typical specs on 8 lug truck hubcaps and what the differences and applications are for each style. 8 lug, 6 lug, 5 lug,etc. Steelies, rally's etc. Pics and any insight would be greatly appreciated... Thanks guys and gals!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 01-29-2012, 09:41 AM   #2
Re: HUBCAP SPECS for 8 lug wheels
You mean what is the diameter? 5-lug and 6-lug are the same...right about 10.5" and all 8-lugs are about 12". This is for outer nub type. Inner clip type are obviously different.
Old 01-29-2012, 10:20 AM   #3
JimKshortstep4x4
Here is a picture of my son's 70 GMC with the 8 lug wheels and correct stainless hubcaps on it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-29-2012, 01:13 PM   #4
jocko
jocko's Avatar
Here's a great ref that someone posted in a thread I started a while back. This shows all the caps for early-mid 70's (but not rally wheel caps, sorry). Yellow bow tie are 73+, blue bow tie are 69-72. Not pictured are the different caps (with red bow tie) for 67-68.
Note that what appear to be some identical caps in the same pic are actually the 2 different diameters for 5/6 lug vs. 8 lug as mentioned above. Hope this helps. One nuance is to note (in the 69-72 blue bowtie pic is that the left 2 caps are a good depiction of the differences between 5/6 lug and 8 lug wheels. Upper left is 8 lug with a concave (bulging) center bowtie while the lower left is 5/6 lug with a convex (sinking) center bowtie. Same can be seen on the upper right and lower right of the same picture. Kinda have to stare at it for a second to see it, like one of those weird pics from the 80's... I do not see the same design feature in the 73+ wheels.
Old 01-29-2012, 02:36 PM   #5
FirstOwner69
FirstOwner69's Avatar
Not meaning to nit-pick this, but to just to clarify. Convex is "buldging" and concave is "sinking" , recessed or cupped. Convex is correct for the 69-72s.
FirstOwner69 is offline   Reply With Quote
Old 01-30-2012, 08:04 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I finally located a set of these (painted variety) in a junkyard for my 3/4 ton. Any tips on how to repaint these? I see some tedious detail brush painting in my future, correct?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-29-2012, 02:05 PM   #7
factorystock
factorystock's Avatar
Jim
This is a common misconception on '69 thru '72 GMC caps. Yours are the '73-'75 stainless editions, (no black center section). The correct chrome 69-72 is shown on this link .http://www.gmcguy.com/gmc_hubcaps_wh..._and_rims.html
factorystock is offline   Reply With Quote
Old 01-29-2012, 02:25 PM   #8
HeavyMetalChevy
Just a Member
Thanks guys!!!!
TH400(3rd)
Old 01-30-2012, 08:13 AM   #9
Masking tape,Exacto knife and spray paint gives the closest to OEM look,since they used a stencil and spray. If you want tedious,try repainting the wheel cover centers. See that yellow ring? Yeah,that and the tiny bowtie need to be painted. Been there,done that.
Old 01-30-2012, 08:55 AM   #10
bobs409
bobs409's Avatar
Thumbs up Re: HUBCAP SPECS for 8 lug wheels
Thanks Tim. That makes more sense than a detail brush in my shaking hands.
Bob
Old 01-30-2012, 09:18 AM   #11
Yeah,maybe a brush would be good,but I was speaking from my blind in one eye can't see out the other shakier than a skunk tail point of view.
