01-29-2012, 12:22 AM | #1 |
relocating fuel tank /fuel filler
I will be relocating my fuel tank to the rear of my truck in the near future and was woundering what people are using. Also I want to install a fuel filler door and not have the fill on the bed floor. please feel free to post photos parts used. I for got to mention my truck is a 69c10 long bed and also currently doing an ls conversion so the fuel pump will need to be in the tank. looking for ideas thanks. I am new to this site and it is awesome.
01-29-2012, 12:37 AM | #2 |
Re: relocating fuel tank /fuel filler
you might be able to use a blazer tank. My current plan is to use a plastic fuel cell under floor but the blazer tank would be better to get the filler off the bed floor, Most of the LS swaps i've seen on here don't use an internal fuel pump but an external frame rail mounted fuel pump from what i've seen. Also alot of people have used custom made aluminum fuel cells for ground clearance as the blazer tank may hang down a little (idk if your lowering bagging it) They can be made to accept a factory sender/pump unit or external with the filler neck wherever you want. I think one vendor on here is named "fuelcellguy" ?? not sure if thats the right name but he makes some dang nice custom fuel cells and I want one !!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-29-2012, 12:46 AM | #3 |
I am using a Walbro GSL392 Universal Inline 255LPH Fuel Pump and Kit (Ebay $100 shipped)
I just snagged this quote from mcbassin, his build thread is at http://67-72chevytrucks.com/vboard/s...d.php?t=354738 That is what Iv'e seen most using anyway. He has a truck 4.8L LS motor but the fuel demands are similar.
01-29-2012, 12:52 AM | #4 |
My truck is already lowerde 4/6 and i will be starting with the in cab fuel tank. Already going to be using a walbro external pump corvette filter/regulator but will up grade later. Also don't want the tank to hang low. Trying to find the post where someone put the filler behind the rear light and maybe the side marker light thanks
01-29-2012, 12:54 AM | #5 |
I'm also doing the 4.8l install
01-29-2012, 05:11 AM | #6 |
Still plays with trucks
The square body 87-91 Blazer & Suburban EFI tank fits and can work really well.
For the fuel door you can run the 88-98 Chevy truck fuel filler door. The curve of the door fit the curve of our quarter panels and the shape looks right too. http://67-72chevytrucks.com/vboard/s...379333&page=29
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-29-2012, 11:06 PM | #7 |
Thanks for the info, keep it coming and pictures also if you've got them
01-30-2012, 10:43 PM | #8 |
i used the blazer tank. i put the filler behind the back up light. it worked out well and fills great.
02-03-2012, 09:35 PM | #9 |
Good idea keep it coming
Posted via Mobile Device |
02-03-2012, 10:20 PM | #10 |
I put mine behind the marker light, I've also heard of a liscence plate fill full size GM car tank used, and....filled behind the rear plate.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
02-04-2012, 09:14 AM | #11 |
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
05-16-2012, 04:36 PM | #12 |
Check my build thread. Mine is behind the left taillamp, I have the ECE 4/6 drop and a 70 blazer metal tank. Hangs a little low, but no problems so far.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
05-16-2012, 05:00 PM | #13 |
69 Camaro tank install - Worked great. I have some pics of mine if your interested. Good Luck!
Texas - Don't Let The Size Scare You! |
05-16-2012, 05:33 PM | #14 |
I like the idea of the filler behind the tail light. It is like the 56 & 57 Chevy's, which I thought was a cool feature back in the day.
Boyd Welding tanks is an option as well, and we have Free Shipping this month on them. They can be built for a carb of EFI application and fits in between the frame rails and appx. 19 gallons. Boyd Welding Tanks - Travis |
05-16-2012, 10:24 PM | #15 |
I have a Boyd Welding tank, fits great. They do a really good job. I tried a marker light filler but it did not work very good, filled too slow so I switched it to the bed floor.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
05-16-2012, 11:57 PM | #16 |
I just roughed in my fuel filler door in the drivers side of my bed. I really wanted the filler behind the drivers tail light but here in Oregon we cannot pump our own gas. Didn't want all that hard work getting hammered by...well you know. I found a late 80's suburban for a donor door and filler neck. It all worked out perfectly. The filler hose and even the vent hose are the right length and size. The rough in only took about and hour.
03-23-2016, 02:34 PM | #17 |
Great info everyone. I'm working on a 58 Apache that now has a 5.0L TPI engine and a 700R4 Tranny. I really want my fuel tank under the bed and it has to be a side fill. I have a fuel tank from a 2003 Blazer. The tank does not fit between the rails because it is 33 inches wide. the measurements betweem the rail walls is 33 and a half. Any good suggestion on how to move forward on this one.
