Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-29-2012, 06:48 PM   #1
Blue Rat
My BBC couple pictures.
I finally got all the pistons in an went back an check clearances this weekend an all is well. Just though I would share. This has been a long time coming. Hopefully have the engine together sometimes in March.
Blue Rat is offline   Reply With Quote
Old 01-29-2012, 11:42 PM   #2
Captainfab
60-66 Nut
Re: My BBC couple pictures.
Looks good
Quite the dome on those pistons. What cubic inch are you building?
Old 01-29-2012, 11:47 PM   #3
mud.man.rj
mud.man.rj's Avatar
ya kickin domes on those pistons, what heads are you using and what compression will it end up being with the chamber size.
mud.man.rj is offline   Reply With Quote
Old 01-29-2012, 11:47 PM   #4
Vortecpro
Now were talking!
Vortecpro is offline   Reply With Quote
Old 01-29-2012, 11:49 PM   #5
Newtz67
Newtz67's Avatar
Specs?
Newtz67 is offline   Reply With Quote
Old 01-30-2012, 06:42 PM   #6
Blue Rat
Guys it is a 427 .030. GM steel crank, Callies rods, solid custom roller for my application an has been balanced. I will try an keep it updated. Went to put my my timing chain cover on it it would not fit right so I could set my camshaft end play. So going try an get time to work on that this week.
Old 01-30-2012, 08:10 PM   #7
Blue Rat
Originally Posted by Blue Rat View Post
Guys it is a 427 .030. GM steel crank, Callies rods, solid custom roller for my application an has been balanced. I will try an keep it updated. Went to put my my timing chain cover on it it would not fit right so I could not set my camshaft end play. So going try an get time to work on that this week.
The camshaft his suppose to be 2800-7000 and the heads are Brodix oval port RR's. Also have the Brodix valve covers.
Old 01-30-2012, 09:31 PM   #8
Newtz67
Newtz67's Avatar
Sweet!
Old 04-07-2012, 05:01 PM   #9
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Man....should have went with the Cloyes quick button timing chain cover. Those things rule! I had my roller endplay set and final in about 7 minutes.
prostreetC-10 is offline   Reply With Quote
Old 04-07-2012, 06:57 PM   #10
Blue Rat
You are not going to believe this but was thinking about what you did the whole time. Just did not want to spring for that money. But it is done now. Never got time to work on it today. May work on it tomorrow after easter stuff is finished.
Old 02-08-2012, 08:16 PM   #11
Blue Rat
Thanks, it has been a long time coming. Going to work on it again this weekend.
Old 02-08-2012, 08:29 PM   #12
OC 72
OC 72's Avatar
Rat...this should have XXX next to the tag line!
Going to be good!
OC 72 is offline   Reply With Quote
Old 02-08-2012, 08:44 PM   #13
Blue Rat
Going to be good!
Thanks.
I try to do things right. Starting with this an get the truck right. I then may go to more cubes in a few years.
I ditched the steel roller cam button for a nylon easier to set clearance with it.
Old 02-11-2012, 11:57 AM   #14
Blue Rat
I sure would like to start on it again. But, it is 21 degrees outside an I am on call this weekend an worked half the night last night. I do not even feel like firing the heater up. So, it is going to wait I guess.
Old 02-19-2012, 09:47 PM   #15
Blue Rat
Got a little more done but no pictures will have some most likely this coming up weekend.
Old 02-20-2012, 09:48 PM   #16
Blue Rat
Couple more pictures.
Old 02-21-2012, 02:13 PM   #17
redsled87
redsled87's Avatar
This thread and me getting my fab work done to my truck has me wanting to get my 496 back even more!!!!!
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-24-2012, 09:10 AM   #18
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Very nice & clean!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 03-03-2012, 09:35 PM   #19
Blue Rat
Thanks,
I am going to try an got the oil pump bolted in place an check its height one last time an then bolt the oil pan in place. Post a pick again tomorrow hopefully. I am on call this weekend 24/7.
Old 03-04-2012, 12:53 AM   #20
redsled87
redsled87's Avatar
What oil pump are you using?
60' 1.49
1/4 10.93
MPH 120
Old 03-04-2012, 09:11 AM   #21
Blue Rat
I ended up going with the M77 pump. Changed out the spring in favor of the high pressure spring. Had the M77HV pump but changed my mind on it. Still have it setting on the table in the box.
I have always used the M77 an never had a problem. "So if it's not broke don't fix it". I heard the argument on both sides. I decided to go with what I know an have always done.
Old 03-14-2012, 12:47 AM   #22
redsled87
redsled87's Avatar
I also have a M77 pump for my 496. The spring that you installed, is that the optional one that comes with the pump? I know SBC's better than the BBC's. I remembered that you don't want a HV oil pump in them either.
60' 1.49
1/4 10.93
MPH 120
Old 03-04-2012, 02:16 PM   #23
RatPwrd72
RatPwrd72's Avatar
I've used both and can only recommend the HV if you are running an oil pan with a capacity of 8+ quarts, this from experience of course.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 03-04-2012, 07:19 PM   #24
mud.man.rj
mud.man.rj's Avatar
Thats the thing on the Big block a little more pressure is better than the Hvolume pump and less of a power robber too.
Old 03-04-2012, 07:45 PM   #25
Blue Rat
That is what I was thinking too. But, I can see it both ways. I just went with what I have always done.
