Old 04-28-2003, 08:53 PM   #1
tai
tai's Avatar
truck saw
i tried to use the truck for a chain saw and cracked my front leaf mounts
any suggestions on replacements
welding isnt a problem
tai is offline   Reply With Quote
Old 04-30-2003, 03:07 AM   #2
1FaastC10
1FaastC10's Avatar
ok, you gotta explain "tried to use the truck for a chain saw" and how and where exactly are the mounts cracked? what kind of truck are we dealing with?
1FaastC10 is offline   Reply With Quote
Old 04-30-2003, 09:04 AM   #3
Shane
Shane's Avatar
i tried to use the truck for a chain saw ...
Shane is offline   Reply With Quote
Old 04-30-2003, 09:25 AM   #4
bpmcgee
bpmcgee's Avatar
Think he took the cover off and tried to cut something with his timing chain?
Brian
bpmcgee is offline   Reply With Quote
Old 04-30-2003, 03:03 PM   #5
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
mabye he used a flex fan those suckers are sharp.
GMC JUNKIE TOO is offline   Reply With Quote
Old 04-30-2003, 03:06 PM   #6
bpmcgee
bpmcgee's Avatar
Ah, of course! Rivet in a few hardened steel teeth and you're all set! It would have quite a kerf to it, but it would work for cutting firewood.
Then I suppose he damaged his leaf mounts because he was using them as kickback preventers?
:p
Old 05-01-2003, 04:10 PM   #7
71-longbed
Its Magically Delicious
71-longbed's Avatar
did you grab a chain around you bumper and try to pull a tree down???? or what
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-05-2003, 02:02 PM   #8
tai
tai's Avatar
sorry to take the mystry out of this but i just took a corner to fast and ate a dug fir the winch, front clip, left frame horn, left front leaf mount, radiator, fan, alternator and stoped just about 1\4in from the block. the truck stop and rested on a 45 with the passenger side door pinned in the mud. we back up in to a pasture, took a 2ton cumalong, ripen off all of the damage, straitened out the tie rod and clutch linkage and nursed the beast home on a gellcell.(those things are of the best investments for any vehicle). i have finished most of the new sub frame and way over built mad max front end cage replacing the stock radiator with aluminium. our shop is not yet complete so the beast has a some what water proof home under a tarp city. the left front leaf mount is cracked in two places. just under the frame and just above the frame. the cracks are about 1in wide and 2in long. any thing i replace the leaf mounts with will ba a definit up grade. any susgestions would be a great help
thanks
oh yeah she was a 71k20 with 6in sus and 3in body lift
dana 44 front
eaton rear
