02-01-2012, 11:35 AM | #1 |
here, just not logged in
Oxygen/Acetylene Torch
I've been needing a torch for a while now. I'll be using it for basic farm use. I'm looking at three different ones. Anybody have any opinions? I'm leaning towards the Lincoln. Only because it's the cheapest and i own a Lincoln welder. So what do y'all think?
Lincoln Ele. $184.00 http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 Victor firepower $219.99 http://www.northerntool.com/shop/too...7990_200357990 Hobart $199.99 http://www.tractorsupply.com/hobart-...ch-kit-3810496 |
02-01-2012, 12:13 PM | #2 |
Re: Oxygen/Acetylene Torch
** Let me add that, "basic farm use" would be cutting maybe 3/4" steel bar or 1/2" to 5/8" steel, as well as working on my truck. I'm just looking for a general purpose torch like you would have in a shop.
02-01-2012, 12:23 PM | #3 |
Hand Crafted C-10
The Lincoln Elect (Harris) appears to have 12' (the ad says 12"
hoses vs 20' on the other two. IMHO--choose a brand that is Victor compatable. I believe the Hobart is... don't know on the Lincoln. |
02-01-2012, 02:50 PM | #4 |
You may also want to look at running it on propane if you don't already have an acetylene bottle and are going to use it for just cutting.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
02-01-2012, 10:25 PM | #5 | |
I didn't notice the Lincoln's hoses were only 12'. I might just spend the extra 20 bucks and get a Victor instead of the Hobart(Victor compatable). I don't know anything about using propane. I'm gonna do some reading about that and see if it would be a better option for me. |
02-01-2012, 11:12 PM | #6 | |
02-03-2012, 09:20 AM | #7 | ||
I haven't had a chance yet, but i'm gona try to get to the welding shop today. I'll see what they have. Quote:
02-03-2012, 04:40 PM | #8 |
Yep propane tank off the BBQ pit and oxy. I have a Victor torch and it's a special propane tip I had to buy.
02-01-2012, 10:29 PM | #9 |
Personally I'd check out your local welding shop, sometimes they have "re-man" that run fine. Also gives you the option to price check the consumables tips, cleaners, more hose (personally I won't even bother to hook up 12' of hose, I prefer more distance between my hot work and the tanks. Then again, I run flashbacks at home too.)
Some shops will also have off brand kits that work fine and use OTC parts. On the job I've used Airco, Victor, Harris and some off brands. Torch tip style is different with the Victor and Airco styles common
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
