Badass
Sitting sidwayz
Okay this is a pretty commen problem with these years of trucks the rear sits a little lower on one side looking from the rear. Mine is the drivers side about 1.5 yes the truck is lowerd but it has the same problem at stock height . It only really is like this in the rear. What could I do to fix this ?
Rotate the leaf springs left from right? Best pic I got with me ![]() Posted via Mobile Device Posted via Mobile Device
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: Sitting sidwayz
http://67-72chevytrucks.com/vboard/s...d.php?t=506212
hope this helps
83 ![]() |
Re: Sitting sidwayz
get a big engine and accelerate hard, all the time
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Badass
Re: Sitting sidwayz
Already Got a decent size motor
![]() Join Date: Oct 2009
Your rear leafs probably lost there arch. Mine did same thing. I Installed suburban leafs and no more lean. I think because of the rear gas tank verses the side tanks. Does it lean on side of your gas tank?
Badass
Re: Sitting sidwayz
Yup drivers tank only. Thinking of swapping left to right leaf
Re: Sitting sidwayz
...looks fine from where I sit...
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Badass
Re: Sitting sidwayz
Lol I'll get a better pic this weekend. It's pretty noticeable
On a budget like Fred Sanford
Re: Sitting sidwayz
Mine had the lean pretty bad, passenger side was higher than driver side. After I lowered my truck and replaced the bed (did both at same time) it sits level again. I did shackles/hangers out back and spindles/cut coil up front. So mine had to be either a twisted bed or hangers/shackles being off somehow.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
![]() Join Date: May 2009
Re: Sitting sidwayz
My right side was a lot lower, it was obvious looking at the leaf spring that the arch was not the same as the left. *I was going to get the springs re-arched but took a gamble at the junkyard and purchased one side for $40.00, worked great. *For once I was able to get by with something cheap. *
It's funny how many of these old pickups you see driving around leaning to one side.* Posted via Mobile Device |
Spear and magic helmet!
Re: Sitting sidwayz
I swapped my leafs from right to left and I'm almost level now
Re: Sitting sidwayz
Mine did the same thing. I actually just ordered new leafs for both sides. I already replaced almost the entire suspension so I figured Id just spend the extra coin and call it good.
