Gauge Lights
What do I need to get to enhance the lights in my gauges? They don't light up much at night, difficult to see almost. Is it a printed circuit?
1984 Chevrolet Silverado |
Re: Gauge Lights
I had the same question/need last Spring...I got some great help that involved removing the gauge cluster and spray painting the inside of the plastic gauge bezel gloss white...wow..what a difference with the light bulbs bouncing the light off the white inside vs the stock blueish plastic...it sounds a bit odd, but man did it work. Good luck
_______________________________________________ 1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger" 1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel |
Re: Gauge Lights
Also, check and replace any burned out bulbs...I had one out
Re: Gauge Lights
Thanks man... I will check into it.
Re: Gauge Lights
While your at it, replace the bulb connectors. Mine were a little corroded and I think it did effect the lighting a little bit. Instead of white I used the redneck rattle can chrome and it came out fine also.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: Gauge Lights
The head light switch is also a dimmer switch for the dash lights. Check for any corrosion or break on the coil of the switch.
78K & 79C Jimmys
Re: Gauge Lights
did this in the fall great improvement(78 jimmy below)
added seperate red LEDS for my colour
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
