02-05-2012, 02:50 PM | #1 |
Wont lay?
I am bagging a 69 C10 shortbed. I have Belltech spindles, QAR plates and cups. I am running a set of 20's with a 255-35-20. My crossmember is about 4" from the ground.
Do you guys have any suggestions? It seems like the bags are compressed but I may be mistaken. The stock shocks are still connected, I didnt know if that might have something to do with it. thanks Brad |
02-05-2012, 05:38 PM | #2 | |
Re: Wont lay?
02-05-2012, 07:57 PM | #3 |
Re: Wont lay?
The inner fenders are out of it? We removed the shocks today still no more drop? I am baffled!!!
I know the cups need to be cut some. But I dont think this will help enough! |
02-05-2012, 08:23 PM | #4 |
Square
Re: Wont lay?
if you remove the bags and cups does it lay? take some pics and post em so we can get an idea of what is going on.
Squarebody Syndicate |
02-05-2012, 11:16 PM | #5 |
Re: Wont lay?
I will get pics this week. This is actually a buddies truck, I am just trying to help troubleshoot the problem.
02-09-2012, 05:04 PM | #6 |
Stirrer of the Pot
Re: Wont lay?
did you do this? I thought guys were cutting out the lower arms to lower the where the bags are mounted as it is. definitely not using big cups. i could be wrong though.
02-09-2012, 09:42 PM | #7 |
Re: Wont lay?
Here are some pics of the front setup. We havent done anything yet, just trying to figure out the best thing to do.
Here is a pic of it as low as it will go??? |
02-06-2012, 04:26 AM | #8 |
Re: Wont lay?
Dose anything like long tube headers or exhaust hang down under the cab that could be it.
02-06-2012, 06:00 PM | #9 |
Re: Wont lay?
He does have longtube headers, that will be coming off soon. However, they are not even close to hitting the ground.
02-06-2012, 09:51 PM | #10 |
Re: Wont lay?
shouldnt have a problem getting it to lay crossmember unless something in the way im running aftermarket spindles with it all the way to the ground. my cross member about 1 1/2 front ground and im running 265/40/r22 its 30.3 inch tire
02-06-2012, 09:51 PM | #11 |
Re: Wont lay?
might have to pie cut your uppers
02-09-2012, 10:00 PM | #12 |
Square
Re: Wont lay?
looks like your bag set up is the culprit. the bags should be way lower into the arms.
02-10-2012, 01:05 AM | #13 |
Happy to be here
Re: Wont lay?
He does have tall cups, but thats not all of the problem. You should be able to lay crossmember with short cups.
02-10-2012, 01:24 AM | #14 |
VA72C10
Re: Wont lay?
Are you sure the spindles are drop spindles and not stock? You won't pick up much with cutting the cups down since too much and the bag will rub on the arm. Should be close to the top of the rim with what you have (drop spindles/bags)
Looking for a 67-72 swb or blazer project in or around VA. |
02-10-2012, 10:42 AM | #15 |
Re: Wont lay?
Yes they are belltech drop spindles.
I my truck, I ran the same setup and my crossmember/ arms would lay on the ground. he is 3-4" off the ground. |
02-10-2012, 10:45 AM | #16 |
Happy to be here
Re: Wont lay?
If you removed the fenderliners and shocks, it has to be the bags. I know some have internal stops, but those don't look to be on the stops yet.
02-10-2012, 12:40 PM | #17 |
Re: Wont lay?
sounds like the bottom cups are to tall. If you have nothing else hooked up and the headers are not touching the ground then the bags are the only thing left.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-10-2012, 01:46 PM | #18 |
Re: Wont lay?
id say take the lower cups out and then see if that makes a difference and shock if you havent already
02-10-2012, 06:17 PM | #19 |
needs more $$$
Re: Wont lay?
It looks like you can take almost an inch out of that cup, which would amount to 2" of more drop given nothing is binding/hanging you up right now. Like everone's said, that's still not going to get you laying the member though.
I thought in order to lay a member on a 69-72 frame, you need to either cup the LCAs or buy tubulars with a built in drop, but 73+ frames can lay member easier...am I wrong?
1970 2wd Blazer |
02-10-2012, 10:23 PM | #20 |
Stirrer of the Pot
Re: Wont lay?
02-11-2012, 03:54 AM | #21 |
Re: Wont lay?
my coil bucket is about an inch or 2 smashed down and im runnng 40series on a 22 and my member is about 1 1/2 from ground so if you have 20s you should be laying crossmember but got to cup your lca otherwise wont have a chance and id get rid of those shocks till you find out what else is stopping you
02-13-2012, 12:34 PM | #22 | |
needs more $$$
Re: Wont lay?
1970 2wd Blazer |
02-13-2012, 02:51 PM | #23 |
Re: Wont lay?
the people i bought it from kinda of ghetto rigid front end bags and rear. thats why im going back threw and puting in a wishbone setup and new airlines and valves and z the frame. they just shoved the bag in side the crossmeber slot there and let it sit on top of the lca hella ghetto right?? im going to get a plate for it soon and cut out the lca
02-12-2012, 05:32 AM | #24 |
Re: Wont lay?
You need to cup the lower control arms. Here is how I did mine, you can see the diffrence between mine and yours..
[IMG][/IMG]
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
02-12-2012, 05:37 AM | #25 |
Re: Wont lay?
[IMG][/IMG]
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
