62 inner door panel arm rest install
I had to deal with the holes being over sized in both the inner and outer panel. So I found a better way to attach the door rests.
I drilled a hole in the inner panel and installed a 1/4 20 nut zert. It came out so well I was shocked. That inner panel has 12 screws holding it to the door. No way to pull it off. My arm rest came from LMC as they do not sell a 62 rest so I have no idea if the hole spacing for a 62 is the same as a 64. But here are the pics and I have new seals so the door still shuts very hard to full closed location. Not even bit of movement on the panel, the plastic handle is another story, but it is what it is. BTW install a new inner door handle assy from LMC, after about a hour a screwing around with it, I got the stock OEM handle to slide onto the splines. I have to say that there stuff is poorly fitting at best.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
Re: 62 inner door panel arm rest install
That looks like a VW arm rest, interesting. My truck didn't have them and I was going to add them if I could. those look great.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Bought them out of LMC ,.. I am no longer fond of there parts.. Just me I guess.. Nothing fits even close, poorly made junk is what I think I bought. But when they is not much to choose from what can you do. The marson nut zert tool is worth its weight in gold. It will allow you to install super clean fasteners where ever you want. I plan on using the 10/32 units in my inner fender wells to hold the wiring into place, my MSD box, fuel line with rubber coated metal clamps along the frame, etc.. It is one cool tool a must have in my opinion.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG Last edited by GMR-PERFORMANCE; 02-06-2012 at 01:54 PM. |
Never Ending Projects
Yep, had my nut-sert tool for more than a decade. It rocks.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
That's bad ass. I could use that to install my headliner! thanks.
I have only used the marson tool & nuts with good quality crimps. I had another that was a off brand and it was a PIA to use. This one is a one pull deal with outstanding crimp on the nut.
I will post up pics of the engine bay wiring once its routed and installed into place. Sure beats using self tappers or the plastic ties that over time get brittle.
Same armrest used from 1955-1965
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Well OEM may be the same but I can tell you what I bought from LMC had .565 wider spacing on the holes. Just a FIY on that. So to use there product you will need to drill new holes, also the spacing is just wide enough that if you use one old hole that the other old hole will just about show where the arm rest is not long enough.
I was just looking at the Harbor Freight version and it looks like junk in comparison. For less than $100, yours looks like it's well worth it.
