Old 02-07-2012, 02:54 PM   #1
slimneverdies
slimneverdies's Avatar
What's easier??
Hey guys, I purchased a camaro to swap parts to and get rid of most of the outdated stuff that came in my 86 c10. The question I had is would it be easier to use most of the parts from the 2000 camaro and have sort of a plug and play type of swap that would only need a tune? I keep reading all these threads about buying part after part after part to make this swap work. Is all this necessary if I have a perfectly running car with all the accessories? So far I have taken everything off the camaro, mechanical and electric. Gas tank, radiator, abs, steering column, entire wiring harness, floor shifter, gauge cluster, rear end, etc
I know it would take some fab work to get this all into a different style car but I have the time if you guys think it's worth it
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 02-07-2012, 02:56 PM   #2
slimneverdies
Re: What's easier??
Long live SLIM
Old 02-07-2012, 07:51 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What's easier??
keep the engine, trans, wiring harness (to rework) and pcm. Everything else just scrap or sell on CL. The airbag'd wheel and steering column wouldn't be something to put in your 86, and the rest of the cradle and suspension components won't really help ya. You can keep the disc brakes for a conversion.
Having the car helps you save time and money with the small parts, power steering lines and things like that. Not really "plug and play" though.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-07-2012, 09:25 PM   #4
slimneverdies
Re: What's easier??
Thank BR3W. After reading thru so many of the forums on here I was under the impression that I could use most of these items. I've seen use of the fbodys gas tank, radiator and most importantly for the ignition the steering column. Is there any particular reason not to use them
Long live SLIM
Old 02-08-2012, 10:41 AM   #5
Clyde65
Clyde65's Avatar
Re: What's easier??
My only 2 cents is after your done you will be saying why didn't I do this long ago!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-08-2012, 11:28 AM   #6
Super73
Super73's Avatar
Re: What's easier??
I think there are certain mechanical parts that might be worth using. ECM, Harness, Engine, Trans, maybe gas tank, maybe colum with out air bag/steering wheel, and perhaps brakes (I am using 4th gen rear disks on the back of my truck after making backing plates).
Even the column, once you do the fab work to get it to fit, find a wheel that works etc. it would probably have been cheaper/easier to have the VATS deleted from the PCM by a competent tuner.
I think trying to get most everything else in would really be a lot of work for next to nothing gained, it it will even work. Just my thoughts.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-08-2012, 02:26 PM   #7
OldCreek
OldCreek's Avatar
Re: What's easier??
Get the fuel pump assembly. Use the gauge panel if you like the styling. Rad and hoses? OBDII port/wiring. Maf sensor. Cruise control/throttle cable box?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-08-2012, 03:20 PM   #8
slimneverdies
Re: What's easier??
I took everything mechanical and electric of the fbody. I even took the traction control off. I was thinking of using the steering column with the c10 original steering wheel. I want everything I can possibly get under the hood within reason.
Long live SLIM
Old 02-08-2012, 08:00 PM   #9
clinebarger
Re: What's easier??
The VATS can be bypassed with a $50 VATS box from painless on 4th gen F-body PCMs.
clinebarger is offline   Reply With Quote
Old 02-08-2012, 11:51 PM   #10
slimneverdies
Re: What's easier??
Originally Posted by kSStamp0182 View Post
DO NOT use that rear end, throw it away or sell it unless it is an upgraded unit.
the 7.5" 10 bolt in those cars are much smaller and weaker than your trucks 8.5"
it would be a time bomb under that power and weight of that truck, keep your stock 10 bolt under there.
I was actually going to snatch the brakes off the rear along with the abs.
I figured since I wanted the tilt steering that this would be an upgrade with plug and play to the pcm. Any other advantages by deleting the vats?
Long live SLIM
Old 02-09-2012, 05:55 PM   #11
clinebarger
Re: What's easier??
You will also need the BCM, And alot of related wiring, Far easier to delete/bypass it & move on, The columns in the F-bodies are junk anyway (tilt pin wearing out the aluminum housing) & the resister keys & cylinder give alot of problems.
Old 02-08-2012, 08:11 PM   #12
kSStamp0182
LSX addict
kSStamp0182's Avatar
Re: What's easier??
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-09-2012, 12:18 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What's easier??
I agree you can keep the tank/pump/sending unit as well, and the rad might work but that depends on dimensions. ABS stuff is for removal only lol, never bothered putting it back on anything.
You could go more like Frizzle Fry did, and try to use the entire donor vehicle as a base....but that was a 'vette and is more of a thesis on fabrication.
Old 02-13-2012, 12:55 AM   #14
Frizzle Fry
Frizzle Fry's Avatar
Re: What's easier??
Hey now The C5+ vette has a full frame. F-Body's are unibody. It's much easier to swap a cab onto a frame than to adapt suspension from a unibody donor.
From an fbody I would use the engine,trans, ECU, engine harness, rear brakes, and rear sway bar. I would look at using the front brakes, radiator, fuel tank, rear axle, seats, cluster, and ebrake parts.
Frizzle Fry is offline   Reply With Quote
Old 02-13-2012, 01:05 AM   #15
slimneverdies
Re: What's easier??
I honestly think I'm going to use everything I can that would be considered an upgrade. Maybe the steering wheel might need to be left alone tho
Long live SLIM
Old 02-13-2012, 01:34 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What's easier??
lol it was a compliment Frizzle. If my build is a bachelors degree, you sir are going for a PhD.
Old 07-01-2012, 01:13 PM   #17
slimneverdies
Re: What's easier??
Hey guys, Is it possible for me to mount this gas tank in this location in the pic? I have the truck torn apart and can't remember exactly where the box attaches to the frame rails....
Slim
Long live SLIM
Old 02-09-2012, 12:20 AM   #18
slimneverdies
Re: What's easier??
Ok. I see what you guys are trying to say. I guess I want a little to much out of the donor.
Long live SLIM
Old 02-09-2012, 12:24 AM   #19
kSStamp0182
LSX addict
Re: What's easier??
the lug pattern, while still 5 lug, is different than ours. its like a 5 x 4.75 too. so the rotors wont be a direct fit
Old 07-01-2012, 08:10 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What's easier??
Is your notch just but welded to the top section of the old frame rail?
Old 07-01-2012, 08:55 PM   #21
mooseknuckles
mooseknuckles's Avatar
Re: What's easier??
wow...it kinda looks that way...
mooseknuckles is offline   Reply With Quote
Old 07-01-2012, 09:10 PM   #22
slimneverdies
Re: What's easier??
This is the old broken frame I'm using for mockup. I have the new frame that will get the complete notch installed top to bottom. Thanks for concern tho, now what about the gas tank lol
Long live SLIM
