Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-07-2012, 04:14 PM   #1
jrb71c20
jrb71c20's Avatar
Help with tires
I wanted to get away from tiny replacements so I put some 235/75/15 on, looked great but rubbed like hell and I thought that was the biggest I could go on the truck. I put some spacers in and now the tires clear but the gas milage is horrible and its a DD so, its rides rough and beats the hell outta me for 64 miles a day.
I'm gonna have to take the tires off and the spacers out. What is is the biggest tires I can put up under my 2wd DD?
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Old 02-07-2012, 04:26 PM   #2
hopped up
hopped up's Avatar
Re: Help with tires
id be interested in the answer too. dropped?stock? gonna need more info. what rims? mine is all stock, factory s10 wheels
hopped up is offline   Reply With Quote
Old 02-07-2012, 08:50 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Help with tires
I have 255/60R17" on my Jimmy. They are 29" tall. Stock height and suspension. The back spacing is 4.5 on the wheels. The front tires hit the frame rails at full steering wheel turn. I had to modify the emergency brake cable bracket on the rear. I ruined one tire cause the Discount Tire tech didn't notice it rubbing when he put it on. Discount replaced the tire for free!! These tires work great with 3.42 gears, 4L60E and 4.3 combo.
Have you corrected the speedometer for the larger diameter tire? You need to add the difference or your milage is really bad.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-07-2012, 08:51 PM   #4
gchemist
gchemist's Avatar
Re: Help with tires
Old 02-09-2012, 10:33 AM   #5
jrb71c20
jrb71c20's Avatar
Re: Help with tires
Its stock rims - 15x7? It will be back to stock height. No sir, I did not correct the speedo. Its a decent lil truck but a DD and I just want a set of tires on there that don't look like they belong on a subcompact.
93 Sonoma 2.8/5spd
Old 02-09-2012, 02:50 PM   #6
gchemist
gchemist's Avatar
Re: Help with tires
Use this nifty calculator to find a tire with your measurements. Once you find a tire, add the % difference at the bottom of tire differences.
I assume you don't want to change the wheels.
