02-08-2012, 05:11 AM | #1 |
WTB Short shift Lever Handle
I need a short shift lever handle that will work in my 72. I'm changing my steering wheel to a smaller aftermarket wheel and need the shorter shift lever. It is a tilt column. I saw on here that the van columns had the shorter levers, if so this is what i'm looking for. Thanks. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
02-08-2012, 05:40 AM | #2 |
Just a Member
Re: WTB Short shift Lever Handle
I should have an extra.. I will get back with you later this morning.
Duane
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
02-08-2012, 07:21 AM | #3 |
That would be great Duane. If you find one post up some pics. I need one with good chrome and no wear on the base where it mounts into the steering column. In other words a nice tight shifter handle. Thanks for checking for me. Joseph
