Old 02-11-2012, 10:16 AM   #1
ChevyC102007
ChevyC102007's Avatar
HELP!! (again)
OK I need ideas, all my gauges stopped working with the exception of my speedometer and Sunpro Tach. What gives? Im thinking either a lose ground or a bad printed circuit. I tried to install a electir fan last summer and the temp gauge froze (think that one grounded out) then the volt, oil and fuel gauges went soon after. Being 30 years old it wouldnt surprise me if the circuit did go bad. Any ideas?
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 02-11-2012, 11:05 AM   #2
Goldfinger
Goldfinger's Avatar
Re: HELP!! (again)
sounds like grounding issues. It could be the circuit but i would explore grounding first.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-11-2012, 11:18 AM   #3
Weasel Diesel
Re: HELP!! (again)
by chance did you check the guages fuse?
Weasel Diesel is offline   Reply With Quote
Old 02-12-2012, 07:02 AM   #4
ChevyC102007
Re: HELP!! (again)
the fuses were the first things I checked. All checked out good.
[Cherokee saying]
Old 02-12-2012, 09:34 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: HELP!! (again)
not sure how it's all wired but may wana look here for ground issues
i even found the bolt holding the ground mount,by the ebrake loose
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
