02-11-2012, 11:34 PM | #1 |
64 4x4 leaf spring question
My father and I picked up his new truck, a 1964 k10. It needs some work but it runs strong but I noticed that one of the leaves is broken on both sides of the front end. So here my question; what springs fit in this truck? Will 73-87 work or are they a different length. Thanks again guys.
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
02-12-2012, 12:40 AM | #2 |
Re: 64 4x4 leaf spring question
64--66 frt. springs are a breed of their own I believe. you can always get some leafs made at a spring shop. but there must be a reason why they are breaking
ron |
02-12-2012, 01:56 AM | #3 |
60-66 Nut
The '73-'87 K series springs are completely different. You could change the truck over to that style, but you would need to change the spring hangers and possibly another thing or two. You would also have to use either a 2.5" or 4" lift spring. I agree that having new leafs made would be the simplest fix
02-12-2012, 09:31 AM | #4 |
1 plus to changing to a later model spring it is longer so the truck would ride better.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-12-2012, 10:00 AM | #5 |
When i had my 61 i changed over to 73-87 springs. It rode much nicer. The easiest fix liked metioned above it to get a spring shop to make a new one.
02-13-2012, 09:53 AM | #6 |
Thanks guys. I think we are gonna get some new springs made.
