Old 02-13-2012, 11:47 PM   #1
gramps77
CA smog legal headers
Are there any headers available that dont need the tube welded in for the smog pump and maybe already come with it? My 77 Heavy Half ton doesnt require ALL the smog stuff (IE catalytic convertor) but must retain the smog pump. Any ideas?
gramps77 is offline   Reply With Quote
Old 02-14-2012, 12:17 AM   #2
Mccoleman830
Mccoleman830's Avatar
Re: CA smog legal headers
Try Hedman headers PN# 69231 or 69831. Both of these headers come smog legal for the c.a.r.b. These seem to be the only ones that I've found that are still available to be made, and are a decent price. Both will be a long tube design and not a shortie header like Edelbrocks discontinued header series. I've phoned Hedman headers a few days ago and it will take about 3 weeks to build these headers and ship to your door.
1978 K-15, 350/350, 4.11's, 17" KMC's, 37's.
Mccoleman830 is offline   Reply With Quote
Old 02-14-2012, 12:36 PM   #3
rfmaster
rfmaster's Avatar
Funny you should mention Hedman. They offer several different version of CARB compliant headers, but expect long lead times as they tend to build to order! I ordered HED-69891 (CA) HEADERS from Summit at the beginning of January and still waiting for Headman to finish them.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-14-2012, 05:51 PM   #4
gramps77
no way around that ball and socket I guess. I never have had good luck with those.
Old 02-14-2012, 06:44 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Sawzall fixes the ball socket issue
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-14-2012, 09:09 PM   #6
kevinr1970
I bought some reasonably cheap ones off Summit (or was it Jegs???) for my '87 crew no more than a year or so ago.
They have pretty thin flanges, and the place for the smog tubes to attach is in a different location than what is stock, but they worked.
I ordered the Edelbrock headers, but had to return them as they flat would not work for me, although I don't remember specificaly why?
I have a case of "sometimers"...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-18-2012, 05:27 PM   #7
djunkie
djunkie's Avatar
I've got the Hedman shorties and y-pipe setup on mine that have the smog injection tubes welded in. Having a hell of a time getting them to seal up. I think the flanges are tweaked or something. Gonna double up the header gaskets and use some high temp rtv to see if it'll work.
djunkie is offline   Reply With Quote
