Old 02-14-2012, 09:10 PM   #1
owner 84
owner 84's Avatar
Painless GM starter
Hi, guys
I have been wondering what I should buy between two starters from Paniless. They have really good starters and they are trusted as I always hear that from some people.
I have GMC 1984 with 350 engine, but painless has a notification which makes me stop doing anything.
It is that(Note; the 51101starter is for a 168 tooth flywheel and the 51102 is for the 153 tooth flywheel. The 153 tooth is 12.85” in diameter and the 168 tooth flywheel is 14.125” in diameter).
which one is for 350 engine?
Do you recommend other brand that has stronger and trusted starter?
their web is:
http://www.painlessperformance.com/w...r&submit=Go%21
this is my truck.
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 02-14-2012, 09:15 PM   #2
sean1969c10
sean1969c10's Avatar
Re: Painless GM starter
Look at your starter, if the bolt pattern is staggered then you have a 168 tooth flywheel / flexplate. Straight across bolt pattern is the 153 tooth flywheel / flexplate. More than likely you have the 168 tooth arrangement. Hope this helps.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 02-14-2012, 09:27 PM   #3
tucsonjwt
I'm not sure about that painless one, but I would research a genuine GM high torque mini starter. When I bought mine I searched my model, engine, trans, and came up with a specific GM part number. My guess is the price is about the same if you buy from online OEM suppliers.
tucsonjwt is offline   Reply With Quote
Old 02-14-2012, 11:34 PM   #4
Jonboy
Slots go on anything!
WWW.alterstart.biz . Check them out, too.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-14-2012, 11:41 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
The 153 tooth I usually found in 50s engines or powerglides
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
