Old 02-15-2012, 07:59 PM   #1
jessewebb
jessewebb's Avatar
60/40 seat ideas
hello, I have a 1969 C/10. I removing the gas tank thats behind the seat, Would like to put a 60/40 seat in it, I have a 2 year old that likes to ride withe mommy and daddy. Anyone have any ideas, I don't mind having to drill new holes for the seat tracks. just don't want one that sits up to high and blocks the rear glass. Anyone have any pictures of there seats installed. I'd like to see them. Tell me what model there out of and the year. Thanks
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 02-16-2012, 12:19 AM   #2
SactoJim
SactoJim's Avatar
Re: 60/40 seat ideas
I used a 60/40 from a late 80's, early 90's Chevy truck. I cut down the brackets a bit to get the back of the seat below the back window, but it really doesn't stick up much without cutting. The earlier seat don't have headrests and at some point they started putting headrests on the seats.....not a big deal if you are going to re-cover.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 02-16-2012, 02:23 AM   #3
woodwright
Enjoying left field
woodwright's Avatar
Not a 60/40, but this is from an 88-98 truck, stock height. It comes up right above the bottom of the back window. It's a really comfortable height.
If you slide the seat forward a little on its mounts, the legs sit right behind the raised front mount pad.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 02-16-2012, 08:18 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 60/40 seat ideas
Here is my 60/40 out of 89 Chevy truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-16-2012, 08:43 AM   #5
jessewebb
jessewebb's Avatar
Thanks guys for the pictures and ideas. I like the speakes and amp mounted in place of the gas tank. I'll be using that idea also. Thanks again for taking the time to answer,,, Already put a ad in the local trader for a 80-90 chevy truck seat
Pete
04 325i lady's ride
Old 02-28-2012, 11:45 PM   #6
schmedly
SactoJim, can you tell me where you got those seat covers. Or did you have them reupholestered?
schmedly is offline   Reply With Quote
Old 03-01-2012, 11:22 PM   #7
b a king
with the thinner back on the seats ,do you feel it gave you anymore room?? i a big guy and thinking of puttiing a set of these in my 67, thanks,bruce
b a king is offline   Reply With Quote
Old 03-02-2012, 12:01 AM   #8
woodwright
Enjoying left field
woodwright's Avatar
I deffinately noticed a difference. My original seat was also worn out, and shorter than it should be. Between that and the thinner back there is more leg room.
Clint
