02-16-2012, 03:36 PM | #1 |
Hand Brake? Parking Brake? Pic's?
Looking at options for the emergency brake and was wondering what everyone else is doing.
I am thinking of an under the dash mount handbrake. Anyone care to share their set up etc.? |
02-16-2012, 04:17 PM | #2 |
Re: Hand Brake? Parking Brake? Pic's?
Take a look at www.lokar.com we are a dealer for them and can help you and save you some $$$$
You can call me if you would like to at 805 485-0382 if you have some questions Justin |
02-16-2012, 08:21 PM | #3 |
funny you should ask....I was actually going to put a handbrake in, but then decided to do a foot brake..took a 73 - 87 foot pedal, cut it to angle it down, and then shortened the side mount to put it closer to the side wall..it'll look factory when done,,,,got the idea from Orrie I believe
02-16-2012, 09:15 PM | #4 |
I'm using a mid 60's porsche 911 hand brake under the bench seat. Got it for $35 on ebay and made building cables REALLY easy.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
02-17-2012, 12:53 PM | #5 |
I used a 90's square body s-10 parking brake, and just a little something I found out it seems that Chevy used the same parking brake cable ends and coupler for many of the trucks and suvs so the junk yards have a big selection of cables that you can make something work for cheap, I have a long bed and mated up the original s-10 cables from the rear end and a cable from 2003ish 3/4 full size Chevy and it works on the s-10 pedal, I drilled and tapped some spacers and welded them to the kick panel to mount the parking brake and I can take it off if needed, not a great pic but gives you an idea
