Old 02-19-2012, 04:43 AM   #1
Number21
Number21's Avatar
Removing 1973 front drive shaft?
Long story short something is messed up in the 4WD on my '73 K20 with the NP205. Can somebody explain to me how to remove the front drive shaft so I can still drive around?
I see four bolts on the front U joint...do I take those out? And then what? What holds the back together?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 02-19-2012, 05:37 AM   #2
Number21
Number21's Avatar
Re: Removing 1973 front drive shaft?
OK, I got the front of the shaft removed. How do I remove the front drive shaft from the transfer case?
Old 02-19-2012, 04:44 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I usually take a big flat head screwdriver or a tire iron and jam it into the driveline where the gaps are for the u-joints by the front of the transfer case. Then get a socket with an extension and turn the drive line till it wont spin. You will have to readjust the tire iron or screwdriver a few times to get to the other bolts. Might be an easier way but that's how I always do it. Good luck
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-19-2012, 11:48 PM   #4
KrazyRay
KrazyRay's Avatar
I pull the front driveline after the cab is removed from the frame. Its a lot easier to get to that way. Just kidding! Its a pita to get those out. Plan on 15-30 minutes.
KrazyRay is offline   Reply With Quote
Old 02-20-2012, 01:00 AM   #5
Number21
Number21's Avatar
HA! I'm already 2 hours in and all I've got to show is blood. I think the 205 transfer case is making it extra difficult to get to. I'm going to try and take the cross member out.
Old 02-20-2012, 09:39 AM   #6
donut
donut's Avatar
What's in your way? I've had the shaft out of the old '73 before and don't remember it being that difficult. (at least nothing stands out in memory, so no ER visit.)
Starter out of the way? Exhaust? I "may" have gone through the tranny hump, but I honestly don't remember.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-20-2012, 08:05 PM   #7
Number21
Number21's Avatar
Originally Posted by donut View Post
What's in your way?
The cross member.
Old 02-20-2012, 08:55 PM   #8
Zebb
Zebb's Avatar
Originally Posted by Number21 View Post
The cross member.
Can you give more detail? I have never seen a front drive shaft that would not come out after you unbolted it. Or are you having trouble reaching the bolts?
Zebb is offline   Reply With Quote
Old 02-20-2012, 09:05 PM   #9
Number21
Number21's Avatar
That's the problem, I can't get to the bolts. Not enough room for a socket and the cross member blocks a wrench.
The front half of the shaft came off real easy.
Old 02-20-2012, 09:12 PM   #10
Zebb
Zebb's Avatar
It's been a long time since I worked on a 205. If your mounts are bad could it be sitting closer to the cross member than it should? If so maybe jacking up the 205 some to give you clearance enough for a wrench?
Old 02-20-2012, 09:14 PM   #11
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Does yours have some kind of skid plate attached to the crossmember? It shouldn't be more than a 20 minute job.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-20-2012, 10:15 PM   #12
Number21
Number21's Avatar
No. I think I've already got the cross member mostly off, just one stubborn bolt left. I hope. Seems like "simple" jobs always cause me the most trouble. Someone told me the 208 t-case leaves more room for this problem.
Old 02-20-2012, 10:39 PM   #13
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
The front output actually sits back further on the 208 vs a 205. When I swapped out the sm465/ np208 in my blazer to a 465/ 205 I had to shorten the front drive shaft. You have a U bolt flange on your truck though and not a round 4 bolt flange correct?
Tony
Old 02-21-2012, 12:40 AM   #14
Number21
Number21's Avatar
Alright, I got the cross member off. Now I can get to the bolts on the back of the shaft just fine. Problem is they're too tight! I'll try and go at it tomarrow with a longer wrench.
