72 K25 front driveshaft removal
Hi all
I have to rebuild the joints on the front driveshaft on the 72 but I am having no luck at finding any information on the removal process. I see 4 bolts that appear to be holding the shaft onto the transfer case but when I removed one oil started to run out.....do I need to drain the case for this job?? Any help would sure be appreciated. |
Grease Monkey
Re: 72 K25 front driveshaft removal
It sounds like you removed the bolts from the seal retainer. Look for a metal strap or small u bolt holding the u joint to the yoke. Those are the nuts or bolts you need to remove to remove the driveline. I'll post a pic later if someone doesn't beat me to it.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Okay, thanks......I'll have a better look and see if I can find them.
Should I remove the cross member to get at them? |
Grease Monkey
no you have to remove the crossmember. Its not that difficult. Here is a pic
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 Last edited by Chevy1TonFun; 02-20-2012 at 08:12 PM. |
No cross member removal needed. Get a box wrench. Rotate drive shaft so that you can get the wrench on it and work it too. Hold the driveshaft from turning with pry bar at the other end. Remove bolt. Your gonna have to feel you way around a little, but it will work. Its a PITA job and its hard to get a decent turn out of the wrench.
Watch out for dirt in the eyes.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
i will 2nd that on the PITA job
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Wow, that is amazing.......a picture really is worth a thousand words!!
Thanks!! I don't know what I would do without this place and all the help that comes from it....... |
