6-71 blower...?
Ok guys... I've looked and can't find what I need. Has anyone successfully squeezed a 6-71 blower and carbs completely under the hood of a 60-66 without hacking a hole? I measured it up and it looks like there's enough room... But..it's going to be very close...? Also... Is there interference with the firewall? I came across a very good deal, But don't want to hack a hole in my month-old paint.
Posted via Mobile Device |
Re: 6-71 blower...?
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Re: 6-71 blower...?
#4 | |
Just here to tinker
![]() Join Date: Jun 2008
Re: 6-71 blower...?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Re: 6-71 blower...?
It measured 14" from from oil seal flange to top of carb. It will be close, but looks like maybe...? I was hoping someone had a pic of one to feed the fire....
Re: 6-71 blower...?
If yer gonna do a blower, you need to look at some of the more modern stuff if you want to keep it under the hood.
-W |
Senior Enthusiast
Re: 6-71 blower...?
There is an earlier thread somewhere that shows this being done. I'll see if I can find it.
Okay it wasn't about blowers, it was about tunnel rams. Here's the thread. It might still provide some valuable information about clearances if you can compare blower to TR dimensions: http://67-72chevytrucks.com/vboard/s...ht=blower+hood Last edited by markeb01; 02-21-2012 at 02:09 PM. |
Never Ending Projects
Re: 6-71 blower...?
You're saying 14" to the top of the carb... what about air cleaners? Unless I was drag racing only, I would not want to run without cleaners. Likely won't fit under the hood.
I know the "small" blowers (like the 142, 172 ones) will fit but a 6-71 is just a honkin' huge blower. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: 6-71 blower...?
Woogeroo: that was the initial idea, but I stumbled across a crazy deal on the 6-71 full setup. I may go to the 177 with Holley injection instead
Markeb01: thanks for the link. Some very good info in there. Chevy mike: looks like the clearance to the top of the hood *may* allow for a home-build sidewinder type filter setup. Gotta clean the air... Blowers don't like that dirt. Posted via Mobile Device |
Re: 6-71 blower...?
Given that you are so close... Could you drop the engine down an inch by either fabricating new mounts or sectioning the crossmember? Then run a K&N low profile cleaner on the carb(s)...
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
Re: 6-71 blower...?
I thought about that.. but I've got a custom stainless crossmember under my T5. Plus it's a pretty low static drop (see pic). I think I'm going to scrap the idea
Re: 6-71 blower...?
It would be great if you could get that to fit. Check out this chart to see what will work for you. Hope it helps.
58 Apache short fleetside ona 64 chassis: ![]() |
Who Me?
Re: 6-71 blower...?
Are you looking for the blower HP or just the look? Have your thought about using a Pro Charger? That will definatly hide under the hood and spank anything around town.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: 6-71 blower...?
I'm looking for a bit of a hp bump, and the look. If I did anything besides a roots-type it would probably be turbos honestly.
#15 |
Who Me?
Re: 6-71 blower...?
Now your talking!!
