02-21-2012, 04:28 AM | #1 |
What's wrong with my 4WD?
A while ago I put my truck into 4WD and something popped....I had to drive home a few miles making a loud thunking noise all the way. The noise continued even when I put it back into 2WD.
First I thought the problem was the hub, but I took that apart and everything looks well. So then I took out the front drive shaft, and now it seems to drive ok. What does that say about my problem? I took out the drive shaft and the thunk noise went away. Is there something wrong with my T-case?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
02-21-2012, 08:44 AM | #2 |
Re: What's wrong with my 4WD?
Pull the front diff cover off an check inside sound like ya broke spider gears maybe
Posted via Mobile Device |
02-21-2012, 02:43 PM | #3 |
Chevys Kick A$$
Yea I was thinking the same thing maybe. I was thinking more along the lines of a broken u-joint in the front drive line though. Didn't you just put new u-joints in though?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
02-21-2012, 05:35 PM | #4 | |
No, U joints are 40 years old as far as I know.
02-21-2012, 05:47 PM | #5 |
Check yer U-joints! Front and rear shaft. My money is on the front though, took the front shaft out and the noise went away, so points to the shaft, or at least the front axle.
02-21-2012, 08:09 PM | #6 |
Is there any way to see if the U joint is bad besides replacing it? The one I have looks ok, but I don't know what I'm looking for...
02-21-2012, 08:23 PM | #7 |
with a u joint there will eather be extar movement or a visable sign
02-21-2012, 08:50 PM | #8 |
Take the driveshaft out and physically move the U-joint around, look for stiffness, twist the caps, see if they still have lubrication in them. The front axle u-joints you can check by lifting one side off and turning the wheel to one side and then spinning the tire by hand, see how it feels.
