Old 02-21-2012, 09:32 PM   #1
Andyboy
Andyboy's Avatar
radiator overflowing
Ok I finally took the old girl out. She did great until I got home and shut her off. As soon as I turned her off I heard liquid hitting the ground. I thought it was tranny fluid, but it was coming from the radiator overflow nipple. i don't have an overflow bottle. The truck was sitting for about 5 years. The truck has a v6 305 what should I check first?
Andyboy is offline   Reply With Quote
Old 02-21-2012, 09:39 PM   #2
brokenspoke
brokenspoke's Avatar
Re: radiator overflowing
Bad radiator cap....
brokenspoke is offline   Reply With Quote
Old 02-21-2012, 10:11 PM   #3
joedoh
joedoh's Avatar
bad thermostat
Old 02-21-2012, 10:26 PM   #4
**grumpy**
**grumpy**'s Avatar
How much fluid?
had you recently topped it off?
could be just leveling itself off.
Drive again and see if it does it. It may find sweet spot and stop.
If its continues, then Tstat, or cap.
Got a gauge? whats temp read?
Road Hounds
**grumpy** is offline   Reply With Quote
Old 02-21-2012, 11:05 PM   #5
Andyboy
Andyboy's Avatar
Hey guys, Yeah I topped it off but left it 1 inch below the top. Cap and thermostat are new. The cap is a 4lbs cap, and the gauge takes along time to read. I went to the gas station and back and it was barely reading above the first line.
What do you guys think about the timing would that effect the temp.?
Old 02-22-2012, 07:44 AM   #6
brokenspoke
I may be wrong but a 4 lb cap is not holding enough pressure...imho
Old 02-22-2012, 01:17 PM   #7
Andyboy
Andyboy's Avatar
Well I turned on the truck but with the cap on(forgot to take it off). I had it on for around 15 mins. and it started to shoot out the overflow nipple, constant flow. Turned off engine. Well the upper hose did get warm while the engine was on and the temp gauge went to mid point then dropped alittle. Then it started shooting out. While the engine is running is the water in the radiator flowing or standing still? Mine doesn't flow. I might take the radiator in and have it flushed, it was sitting for around 5 years and summer is around the corner.
Old 02-21-2012, 11:36 PM   #8
Woogeroo
crud/debris blocking the air flow across the radiator... either in front or behind. On the grill or on the radiator itself.
does it have a shroud?
since it has been sitting up, check the water pump and see if any coolant is 'weeping' out of the pump at the small little 'weep hole', if so, it needs to be replaced.
does the top hose coming off the thermostat get warm at all? If not hot, the stat may not be opening, even if it is new.
WITH THE ENGINE COLD: you want to have the cap off, crank it up and let it get to operating temp... then watch where the fluid level in the radiator drops to when the thermostat opens... or if it opens at all(keep an eye on the temp. gauge too). If the level does drop have some fresh mixed up coolant to add to top it off. Be sure to put the cap back on snug BEFORE shutting the engine off or it will puke. Good leather work gloves or some thick rags may come in handy. This is the method I use whenever I do work on my radiator/water pump/anything that may have led to a loss of a lot of coolant. That way I know the pump is pulling water through the whole engine.
My pops taught me that one.
-W
p.s. as for an overflow bottle... any kind of container that can handle hot liquid can work.
Woogeroo is offline   Reply With Quote
Old 02-21-2012, 11:51 PM   #9
Andyboy
Andyboy's Avatar
-W
It does not have a shroud. Water pump is new also. I'll have to check the other two things tomorrow. thanks
Old 02-22-2012, 12:03 AM   #10
Woogeroo
Let us know what you find out!
-W
Old 02-22-2012, 02:38 PM   #11
1963c-10
1963c-10's Avatar
Might check the heater core also if its runs without a valve.
1964 Short bed trailer
Old 02-22-2012, 05:44 PM   #12
Bears63
...just another truck junkie..
Bears63's Avatar
Check the radiator cap!!! A 4 lbs cap is nowhere near enough to hold the pressure. It's going to open and there goes your coolant. You should have about a 13 lbs cap on that thing. Try that first.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 02-22-2012, 10:30 PM   #13
T Smith
T Smith's Avatar
It's not going to stay full without a coolant return system, it will find its sweet spot and run an inch or so down, the coolant has to expand and go some where then when it cools it will be low, that's the nature of the beast.
T Smith is offline   Reply With Quote
Old 02-23-2012, 05:01 PM   #14
Andyboy
Andyboy's Avatar
UPDATE: Well I took the radiator to a shop and had them boil it. They said it wasn't plugged up to bad, and had 2 pin holes on top. So I installed the radiator but when I checked the oil, It smells like gas. So the fuel pump will be here tomorrow. I also have to buy a overflow tank and install that, so as soon as I put it back together I'll let you guys know. Thanks for all the feed back.
Old 02-23-2012, 06:24 PM   #15
MisterC
MisterC's Avatar
Good luck Andy! I don't know anything about those V-6's, but mine was doing the same and I had the guys over at Visalia Radiator go through it. Works like a champ now!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-24-2012, 06:53 PM   #16
maxwoof
As posted earlier, coolant will overflow as it expands when it gets hot. This is magnified after shut down as the heat from the block is absorbed by the coolant which is still. Enough coolant will be forced out of the overflow until ultimately only air is discharged by coolant expansion. In my 62, that puts the level at just above the core. No more drips once this level is reached.
maxwoof is offline   Reply With Quote
Old 02-24-2012, 09:25 PM   #17
gimmy 64
i'am not sure if this your problem but alot of people on here are not old enough to remember that before what would you call it --sealed cooling systems it was normal for your car or truck especially if driven on the freeway to puke some coolant on the ground after you stopped engine.that is why alot of guys put catch cans on there cars to not be embarased by your car or truck marking it's spot
gimmy 64 is offline   Reply With Quote
Old 02-28-2012, 10:10 PM   #18
Andyboy
Andyboy's Avatar
Well I got it all put back together and so far so good. I guess the radiator just needed to be cleaned out. Also I'm using a 7lbs. cap and I installed a overflow tank. It didn't puke today so, looks good. Thanks for every ones input.
Old 02-28-2012, 10:55 PM   #19
MisterC
MisterC's Avatar
Sweet! Glad to hear it.
Old 02-28-2012, 11:02 PM   #20
64shortbox
64shortbox's Avatar
Glad everything worked out OK. What about the fuel smell in the oil? Is that gone now also?
64shortbox is offline   Reply With Quote
Old 02-29-2012, 04:54 PM   #21
Andyboy
Andyboy's Avatar
Thanks, and yeah I changed the fuel pump and oil and it seems good.
Old 02-29-2012, 05:02 PM   #22
MisterC
MisterC's Avatar
Does that mean you're good to drive with me to the CPP gathering on the 16th???
I upgraded my AAA membership so no fears on my part.
Old 03-02-2012, 12:29 PM   #23
Andyboy
Andyboy's Avatar
I wish, I still have to do the brake system. It would be nice.
Old 02-29-2012, 12:16 AM   #24
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My guess is it was the new radiator cap. That extra 3 lbs. can make a big difference. Heck, I didn't even think you could buy one less than 10 lbs. rating.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
