Old 02-22-2012, 11:36 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Hole in burb deck for pick up/sender access?
I did some searching but didn't find what I need. I'm thinking about cutting an access hole in the rear floor of the '69 suburban for access to the fuel pick up tube/sending unit. Has anyone done this or have measurements to do it? Thanks for any assistance you can offer....
LockDoc
Leon
Old 02-22-2012, 11:41 PM   #2
vectorit
What?
vectorit's Avatar
Re: Hole in burb deck for pick up/sender access?
My original floor had that done.
I didn't take any measurements, since it was getting removed for a new floor.
I will look at my old pics to see if there is one of the floor, and perhaps you can get a rough idea as to where the hole should be cut.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-22-2012, 11:46 PM   #3
Ironhorse
Ironhorse's Avatar
Leon, sounds like a good idea to me, The General should have made an access cover from the factory back in the day. I had to drop the tank in a
'91 4x4 Burb I owned several years ago and thought about doing the same thing using a scarp piece of bed floor for a plate covered by the carpet. Never got to it and sold the Burb but I think it's a great idea for someone keeping a Suburban for any length of time especially with the newer in-tank fuel pumps and senders.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-23-2012, 12:02 AM   #4
vectorit
What?
vectorit's Avatar
Well, it seems I never took a pick of the floor itself.
But I found one that I took just before the tear down.
You can barely see the spot where the access is, so I put a pointer to where it is.
Basically a hole saw was used, and a strip of sheet metal to hold the center section to the floor.
Probably not good enough for you, but I thought I would try any ways...
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-23-2012, 01:00 AM   #5
LockDoc
LockDoc's Avatar
That's what I was thinking. If I do end up keeping this for a while I don't want to have to drain the tank and drop it when I have a problem with fuel supply or sending unit.
Thanks Chris. That at least gives me an idea where the unit location is. I will do a lot of measuring before I attempt cutting it.
LockDoc
Leon
Old 03-04-2012, 06:20 PM   #6
olblue60@aol.com
member
I'm surprised that after all of these years access like this has never been addressed. I had to replace the fuel pump in my 1996 tahoe and wondered why no one has ever thought to put access to do this either. The tank was a PITA to remove.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 03-04-2012, 10:14 PM   #7
LockDoc
LockDoc's Avatar
I did this yesterday and took measurements and pictures. All I have left to do is make some trim for around the hole so I can set the cut out piece back in. I will try and get that done tomorrow and post it up in a new thread.
Edit: Here is a link to the "How To" thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=523582
LockDoc
Leon
Old 03-05-2012, 12:34 PM   #8
1971BB427
1971BB427's Avatar
I need to drop my tank to address the sending unit and a leak I have when the tank is really full. I it was only the sending unit I wouldn't hesitate to cut a hole in the deck. I would probably just cut a piece of 16 ga. steel a couple inches larger and drill holes to screw it down to the wood deck.
1969 C10 Suburban 350
1963 Falcon gasser 464 BBC
1946 Austin 327 SBC gasser
1971BB427 is offline   Reply With Quote
Old 03-05-2012, 01:24 PM   #9
LockDoc
LockDoc's Avatar
My tank was pretty much full too. It was easy to siphon the gas out through the sender hole...
The 16 Ga metal would work just fine but I always like to do things the hard way...
LockDoc
Leon
Old 03-05-2012, 01:32 PM   #10
1971BB427
1971BB427's Avatar
My Burb has factory carpetting in the rear, so I figure the carpet can be rolled back once the plate was installed and nobody will ever see it.
