02-23-2012, 02:19 AM | #1 |
Do I need to re-grease my wheel bearing?
Been having some problems with my truck, I took the driver side hub off a few weeks ago looking for a problem, but it wasn't there. I left the hub off for a few weeks in the weather, now there's some leaves stuck to the end of the axle in the grease.
I wiped the end off and it looks pretty clean...can I just put my hub back on, or do you think I should re-grease the entire bearing?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
02-23-2012, 02:28 AM | #2 |
Re: Do I need to re-grease my wheel bearing?
Well it's not a bad idea is it? Just clean it out and repack
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-23-2012, 02:30 AM | #3 |
Long story but it's a job I really don't want to start right now if I don't have to. Too much other stuff going on...
02-23-2012, 02:35 AM | #4 |
I see that new wheel bearings are only about $15. Do I have anything more than that to lose?
02-23-2012, 07:16 AM | #5 |
other than the $15 the time and effort.
If you dont have time to do it right the first time, when will you have time to go back and redo it? trash in the grease? no question it should be totally cleaned and repacked. |
02-23-2012, 07:44 AM | #6 | |
Let's just say I'm learing as I go with this truck, and I've had enough learning for now. I just took the front drive shaft out because I didn't want to fix it right, right now....
02-23-2012, 09:25 AM | #7 |
Robert Olson Transport
your mind is made up what you want to do.. to do it right clean and repack and replace if bad if you want to do it halfway and wrong then just throw it together.. heck dont even bother to put in grease i mean heck youre only gonna take it apart again sooner or later forget trucks one of the best lessons you can learn in life is do it once correctly
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-23-2012, 07:34 PM | #8 | |
02-23-2012, 08:44 PM | #9 |
since we're on the topic, how do you guys feel about those bearing packers that you just pump grease into with a grease gun? ehh, i've always done it by hand...
1985 Chevrolet K-10, SWB, 350/700r4, 6" Lift, 35" tires |
02-23-2012, 08:45 PM | #10 |
It can be done in less than an hour just pull the brake off and take out the rotors take the inner bearing races out and shove grease in all the rollers. Put it back together and torque the nut to 75ftlbs I think then turn the rotor a few times. Loosen it up and put the not on about finger snug. Put the pin in and fill the grease cap and hammer it on and your done
