Active Member
![]() Join Date: Oct 2009
Need vent windows restored
Hi is anyone on the forum here good at redoing vent windows puting new seals on. Thanks Doug
Re: Need vent windows restored
I had just done mine the other day. Not too hard, but if you get the ones from LMC make sure you order 2 of the seals or you will only be half done. The book says you only need one, I had only about 6" left after doing one. (I assume that you are talking about the seal that holds the vent window into the metal that is.)
![]() Join Date: Aug 2007
Its a pretty easy job, I would reccomend the set from GMC pauls on line and the install kit is an extra $12.95, makes it much eaiser. I have not had the best luck with some of the LMC door seals
Scotts72C10 |
454 MAKES IT ROAR
Read these...they may offer some help. There's a link from mbgmike who sells the kits to rebuilding in the second thread.
http://67-72chevytrucks.com/vboard/s...t+window+seals http://67-72chevytrucks.com/vboard/s...+window+debate
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Active Member
ttt
Active Member
ttt
