Old 02-27-2012, 09:29 PM   #1
JRHernandez88
JRHernandez88's Avatar
Rear bumper installation and sag question
Whats up guys I just bought my first truck and am about to start restoring it. I took a few pics for ya'l to help me out because i'm about to buy a rear bumper for it and wanted to know if all i need is the mounting brackets and the bumper. It looks like it was cut before so i need to know exactly what i'm gona need.
Also my bed sags on the rear of the driver side. The front of the bed looks straight its just the driver side rear corner. Has this happened to any of your trucks if so what was it? I was just curious and thought I might as well ask before i start getting into it. Any help is appreciated thanks.
71' Chevy C10 Stepside
My Build Thread
http://www.67-72chevytrucks.com/vboa...d.php?t=511087
JRHernandez88 is offline   Reply With Quote
Old 02-28-2012, 12:22 AM   #2
JRHernandez88
Re: Rear bumper installation and sag question
anyone got any tips?
My Build Thread
Old 02-29-2012, 12:25 PM   #3
57larry
always park on a side of a hill
57larry is offline   Reply With Quote
Old 02-28-2012, 12:18 PM   #4
OldCreek
OldCreek's Avatar
Your frames been cut from a long bed to a short bed. It looks like from the first picture that the frame is bent, also.
You may need to remove the bed to get a better look at the frame. Do the coil or leaf springs look the same on each side? Same size tires?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-28-2012, 01:12 PM   #5
72peace
72peace's Avatar
Would this fall into the category of "Who's bought a truck and then found..."?
Cheers and good luck with that,
72peace is offline   Reply With Quote
Old 02-28-2012, 01:45 PM   #6
m6z
m6z's Avatar
There's going to be some fabrication involved to put a bumper back there. Good luck. I'd take the bed off and see how they shortened the wheelbase.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 02-28-2012, 02:31 PM   #7
rsavage
rsavage's Avatar
I'm not sure that your frame has been shortened - it may have just had some notches cut out of the ends. Ask someone with a short step to post some pictures. If it is a longbed frame, the sectioning is done most normally behind the cab. Take a look to see if you can see the cuts and welds if it has been done. It appears that there is a spacer between the frame and bed on the back mount on one side and not on the other side in your photos. If that is the case, the corner with the spacer will obviously be higher. Join the board and post a wtb ad for a set of used stepside sport bumper brackets. I am sure that you can get them bolted/welded on. It will be easier for correct placement if they are bolted to the bumper you are going to use.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-28-2012, 02:54 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
To shorten a long bed frame you take 12" out of the middle but you also take 8" off of the back of the frame rails.... So they cut the notch then just torched off the part that stuck out beyond the bed.
LockDoc
Leon
Old 02-28-2012, 03:41 PM   #9
JRHernandez88
Doesn't sound too good gona have to check it out afterwork. Does anyone got any pictures of what other part of the frame is cut to shorten it? Also if it is cut what kind of problems does that cause.
My Build Thread
Old 02-28-2012, 08:46 PM   #10
LockDoc
LockDoc's Avatar
There are at least 3 different ways to cut a frame. Straight, 45º, and step cut. I step cut mine because I think it is the strongest, 45º is next, and straight is the least desirable. This is my opinion and doesn't necessarily agree with the views of other people on the board.... No matter which is used there should be a plate welded on the inside of the frame over the cut, so it should be easy to find. It should be towards the back of the cab. If done correctly and welded by a competent welder there should be no problem with a cut frame... This again is my opinion.
LockDoc
Leon
Old 02-28-2012, 11:09 PM   #11
JRHernandez88
Thanks for the heads up I appreciate it fellas. Now just time to get this bumper put on.
My Build Thread
Old 02-28-2012, 11:11 PM   #12
JRHernandez88
LockDoc
I took a look after work and I did see the cut. Im gona have to get it on jacks and in the light to see what type of cut they did. Thanks for the info man gona check it out soon.
My Build Thread
Old 02-29-2012, 12:27 AM   #13
LockDoc
LockDoc's Avatar
No problem. I hope you find a satisfactory modification... Any more questions ask 'em up...
LockDoc
Leon
Old 02-29-2012, 01:36 AM   #14
JRHernandez88
LockDoc
ok then out of curiosity how did you put your bumper on? got any pics or tips?
My Build Thread
Old 02-28-2012, 04:04 PM   #15
rsavage
rsavage's Avatar
Leon's right. I had forgot the 8" that is usually cut off the back in addition to the 12" off the wheel base up behind the cab.
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-29-2012, 07:08 PM   #16
OldCreek
OldCreek's Avatar
I guess you could always shim "up" the low sides of the bed and the cab...
