Old 02-28-2012, 11:53 AM   #1
Devil Pup
Devil Pup's Avatar
Gauge swap
Hey guys so i want to do an LS swap and have been doing a lot of reading. With the gauge cluster do i have to use the same year as the motor if i want new style gauges. For example i really like the 2007-9 gauges and would like to run those. However the motor i am prob gonna end up with is gonna be 02-04. Will the wire harness still allow me to run the newer gauges or are the plugs different? Thanks in advance for any help
Devil Pup is offline   Reply With Quote
Old 02-28-2012, 02:45 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gauge swap
Do you really want to mold the whole cluster from the newer vehicle in? IMO you can get the same functionality and sometimes even better performance from a setup of aftermarket gauges, plus it would be easier to fit in the stock dash. The gauges in the new trucks require a BCM, so you would also need to find a place for that, and the wiring.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-28-2012, 02:49 PM   #3
Devil Pup
Devil Pup's Avatar
Re: Gauge swap
BDM i assume is a brain basically?
Im not 100% set on it i just thought it would be cool to use the stock bezel and flush it into the stock bezel but have the new gauges to monitor my motor.
Old 02-28-2012, 02:52 PM   #4
ls1nova71
ls1nova71's Avatar
Re: Gauge swap
It would be hard to get the drivers information center to stop telling you what all systems are not installed in the truck. Dumb things like low washer fluid and such.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-28-2012, 04:11 PM   #5
Devil Pup
Devil Pup's Avatar
Re: Gauge swap
I didnt even think about all of those. That kinda rains on my plan there haha
Old 02-29-2012, 09:55 AM   #6
awhite4557
awhite4557's Avatar
Re: Gauge swap
I used a Dakota Digital set up. They were easy to hook up to the PCM wiring and have everything you need including the check engine light, gear indicators, etc. They have the metric temp sender for the head and the oil preasure sender was tapped into the block off by the oil filter. Works great.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 02-29-2012, 11:20 AM   #7
Devil Pup
Devil Pup's Avatar
Re: Gauge swap
Your dash looks really nice. . . I love the digital, i was just trying to veer away from the norm. Maybe this will have to be a route to look into though. Thanks for the pic!
