02-28-2012, 03:33 PM | #1 |
1950 Chevy rear end problems? newbie
I just bought a 1950 chevy truck and while trying to replace a wheel cylender I noticed two things 1. I have an axle that I have no clue were it came from and 2 they used the factory leaf springs and now the shackles are bent. Ill attach the pic of the shackles. I need a cheap option please!!! but I want to make it right. open to anything TCI leaf kit / Juck yard ...
The only stamps on the axle are HA 10 06 W Thanks guys! |
02-28-2012, 05:16 PM | #2 |
Re: 1950 Chevy rear end problems? newbie
Are your axle perches welded or just bolted on? Looks like they have moved in board, or someone just used the stock ones which caused the springs to twist.
look here: http://www.thecamaro.com/Decoding/Ch...Axle-Codes.php http://www.novaresource.org/axle.htm http://aplsweb.com/Topics/Differential.htm
Retired and too busy to work. Last edited by oldcouple; 02-28-2012 at 05:33 PM. |
02-29-2012, 11:01 AM | #3 |
to me the bushings are toast and/or bolt goin threw the springs is shot. easy fix
03-11-2012, 05:02 PM | #4 |
[QUOTE=oldcouple;5218975]Are your axle perches welded or just bolted on? Looks like they have moved in board, or someone just used the stock ones which caused the springs to twist.
the perches are welded but that axel didnt come original in that truck. Still cant find anything for that axel code. found some wheel cylinders that fit but now I have to find a pinion seal for it. Thanks |
03-12-2012, 01:49 PM | #5 |
Fixed your pic, it was giving me a neckache
Retired and too busy to work. |
03-12-2012, 02:56 PM | #6 |
That does help. Im starting to lean to a 1965 rear end from a truck non posi. but just a hunch I still have yet to find anything on it besides being a 12 bolt but here is a pic
