Old 02-29-2012, 06:31 AM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
engine id help
Block # 3970010 head # 3973487 can anyone tell me some info on it please thanx
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 02-29-2012, 08:19 AM   #2
BigBlocksRule
Re: engine id help
350 block (no way to tell if it's a 2 or 4 bolt block without pulling the pan), '71 - '72 75cc chamber heads. If the block is also a '71 - '72 casting, it should be a good one. If it's a 4-bolt block, check the 3 center caps, if they have "2482" cast into them, they're nodular, stronger than plain cast iron. Also, check for 010 020 under the timing cover. If you have 'em all, you have the strongest stock block GM built.
BigBlocksRule is offline   Reply With Quote
Old 02-29-2012, 08:24 AM   #3
xrcr
Re: engine id help
Heads int ex
1968-72 3973487 350 1.94 1.5
1968-73 3973487 350 2.02 1.6
Engine
1969-79 3970010 350 185 370 2 or 4 car, truck, Vette
1968 3970010 327 - - 2 A
http://www.73-87.com/chevy_ids/sbcid2.htm[/URL]
This what I found
xrcr is offline   Reply With Quote
Old 02-29-2012, 09:26 AM   #4
81ratrodc10
house of chevy's
Re: engine id help
Ok so the guy says its a 69 2 bolt main with a 4 barrel quadrajunk on a aluminum intake what cam would u recomend with those heads if i change to my holley 600 and rpm intake its going in my c10 its a daily driver so just tryin to wake it up alil bit nothin crazey thanx
1987 m1028 cucv d30
2001 chevy s10
Old 02-29-2012, 07:09 PM   #5
81ratrodc10
house of chevy's
Re: engine id help
Anyone
1987 m1028 cucv d30
2001 chevy s10
Old 03-02-2012, 06:43 PM   #6
81ratrodc10
house of chevy's
Re: engine id help
No one can help me here
1987 m1028 cucv d30
2001 chevy s10
Old 03-02-2012, 07:04 PM   #7
rfmaster
rfmaster's Avatar
Re: engine id help
You need to post a bit more information - such as:
Stock pistons? Stock rotating assembly
How many miles on the engine?
Previously rebuilt? What was replaced or upgraded?
Cylinder head combustion chamber? 75cc smog heads
Transmission type (manual/automatic)
Rear end gears and tires diameter
vehicle type, weight
Intended usage.
Your expectations from this engine.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-02-2012, 07:35 PM   #8
81ratrodc10
house of chevy's
Re: engine id help
yes
Unknow pulled from a street rod
I would guess when it was putinto the street rod at least some kinda rebuild
Not sure the head # is 3973487
Auto
Noy sure on gears im runnin 235/75/15 tires
81 shortbed c10
Intended usage.
Daily driver ocasional shows
Better than my 305
//RF
Answered best of my abbility
1987 m1028 cucv d30
2001 chevy s10
Old 03-02-2012, 09:32 PM   #9
rfmaster
rfmaster's Avatar
Re: engine id help
For a near stock engine I would use Sealed power CS-1014R and HT817 lifters. This a good RV style cam shaft and work well with stock to slightly modified engines. It is also inexpensive (Northern auto parts)
//RF
"The Beast"
