Junior Member
![]() Join Date: Dec 2011
Diesel Power Options
I am looking for some information and opinions of the Banks Sidewinder Turbo System for the 6.2 Detroit Diesel.
For those who may have this system installed is the performance gains worth the cost of the system? I am a huge diesel fan and want to get some more power in my truck. I'd prefer to stick with the 6.2 engine but for the cost of the Banks Kit i could be well on my way to joining the Cummins Swap Bandwagon. I already intend to convert from SM465 to NV4500. My truck is a 1985 K30 with the 6.2/SM465/NP205 setup. Thanks in advance for the help.
If it wasn't for the last minute, nothing would ever get done. 1953 3800 - SRW C&C Dump - 216/SM420 1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold) |
Re: Diesel Power Options
you could find a 6.5 and overdrive trans and direct swap too rather than cummins
or swap in a 6.5 turbo to your engine |
I know the pieces fit
You can use the turbo parts from used 6.5 engines on the 6.2 for much less coin. I'd like to do it to mine but don't understand all the diesel engine components well enough to have tackled it yet. Keyword being yet.
yeah what i was saying. theres a write up on the net i have seen. maybeye on diesel place.
The banks makes more power than the 6.5 turbo, on a 6.2 or 6.5.
You can put the 6.5 turbo on the 6.2 in a square, but it takes some mod-ing, the down pipe goes straight towards the frame and the turbo will not clear the under hood A/C box. Not an issue with the non-A/C trucks or aftermarket A/C. The banks kits are very nice, but so expensive. Keep your eyes open and you might find one used. There is one on Craigslist up here. Like new for $1600. There are a couple other aftermarket 6.2 turbo systems. One is ATS....I can't remember the other at the moment... Posted via Mobile Device
#6 | |
If you do go cummins look at the 4bt its a little harder to find but i seen one in a f250 with a work truck steel box on the back get 28mpg even as a 4x4.
The 4BT has less HP and torque than a N/A 6.2L...
What's the advantage of it over a 6.2? Fuel mileage? Posted via Mobile Device
![]() ![]() Last edited by joe231; 03-01-2012 at 12:44 PM. |
1987 R10 Chev Suburban 6.2L Diesel 1984 Frame 1990 Body V20 Chev Suburban 6.2L Diesel Banks Turbo |
Junior Member
Of course cost is always an issue, but i have been saving for this truck project for a long time and i think the Banks Kit is the best way to go to get power out of the 6.2 Diesel.
Do any of you have experience driving a truck fitted with the Banks Kit and were the performance gains satisfactory?
#11 | |
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
for 1600 bucks you could buy a good 6.5 and 4l80e out of a junker or any 12 vavle. for about 2-3k you could pick up a duramax and swap it. that just isnt really cost affective imo.
I have a friend with a 1 ton crew cab, 4" lift with 35's.
He has the banks kit and loves it. I havent driven it...yet! He has had 6.2's with a 6.5 turbo. He told me he prefers the banks set up. I am getting a 6.5 set up from him, now I just need to decide which truck is getting it ![]() I thinking about fabbing up a center mount... The cummins swap craze is getting old IMO. Its much cooler to me to turbo a 6.2 with 6.5 stuff or the banks stuff... Posted via Mobile Device
Agreed. If my 6.2 lets go nothing but another 6.2 will replace it. Possibly a 6.5, but nothing else. I didn't give these engines any respect when they were new but you see so many of them still running now in stock trim, great engine.
#15 |
![]() Join Date: Oct 2006
Could not agree more. It is an EXCELLENT engine,but way over played now.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#16 | |
It all depends what your goals are. If you are looking to suprise vettes, camaros, challangers, and mustangs with a 1ton then the 6.2 and 6.5 aren't going to cut it. The parts for the 12v cummins are cheep, you could do a D-max but the injectors alone are stupid expensive read you could get a very nice turbo for the price of a good set of injectors. buy the same token if you are looking for adequate power and really good mileage then the 6.2 and 6.5 are EXCELENT options. Played out?? ![]() |
#17 |
Junior Member
I'd like to thank everyone for their information and advise.
I too agree that the novelty of the Cummins Swap is wearing off. I have decided to swap in a complete 6.5L Diesel and try also to find a NV4500 at the same time. Luckily my truck already has the Round 6-Bolt, 32 Spline, NP205 so it should make that more easily accomplished.
#18 | |
#19 | |
#20 |
Junior Member
Thanks for the heads up on Stans Headers. I'll be sure to take a good look at them.
#21 |
There may be other headers out there for this application so let us know what you find. Also, keep in mind a header that fits a GM 6.5L will also fit a 6.2L. Also, keep in mind that whether you go with a Banks turbo or headers/exhaust, it'll be a lot better but still won't keep up with the big boys. The Banks turbo only puts out about 9 psi max vs 40 psi on a Cummins. Yes, you can put on a bigger turbo for more boost but the 6.2L probably won't survive very long. The compression ratio is too high and the bottom end is too weak for that kind of boost.
#22 |
maybe I shouldnt have said "played out",as there are some VERY sweet builds using the Cummins. That being said, I dont think the average joe can afford the cost of the swap,so in an economic stand point,the 6.2/6.5 would be a GREAT choice for diesel power,you dont have to buy special adapters or trannys,custom make mounts,etc....
but yes, the small block chevy in anything BUT a chevy gets old. I hate seeing old Fords,Dodges,IHs,Amercans and such with the famed "SMALL BLOCK CHEVY"
#23 |
The reason so many cummins are swapped is they are easy to get and cheaper to make power with.If you want just a diesel for normal use the 6.2 and 6.5 are perfect.If your looking for a truck to drive and light use a 4bt isn't that bad and can be modded easy to make more power.
#24 |
Junior Member
I'm going to be looking for a Turbo 6.5L with Mechanical Injection from 92-93.
I was never going for amazing power levels, I just need a little bit more to pull the boat around town and get it up the boat ramp more comfortably. Starting every traffic light in granny gear (L) and having to wind out the engine in second gear before shifting into third so it doesn't lug makes me uncomfortable. Having looked at it i think a 92-93 6.5L with the early NV4500 will provide what i am looking for.
#25 | |
If you do decide to install a 6.5L, check carefully for bottom end cracks in the webbing area before buying. I've rejected too many otherwise good engines because of this.
