Old 03-02-2012, 08:46 PM   #1
72farmer
What caused paint to wrinkle on steering column?
I tried to paint my van tilt column yesterday and something was wrong?I cleaned it up w/ lacur thinner sanded it w/600 grit and then wiped it down w/ mineral spirits an painted it with the spray can shown and immediately it started wrinkleing and pitting.Now i will have to let it cure,sand it again and try to spray it again.What do you think caused it to do this?
72farmer is offline   Reply With Quote
Old 03-02-2012, 08:53 PM   #2
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Re: What caused paint to wrinkle on steering column?
How cold was it and how old it the paint. You my get better results using a good primer then paint.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 03-02-2012, 08:59 PM   #3
67swb72klb
67swb72klb's Avatar
u need to wipe down with wax & grease remover before paint those are called fish eyes from oil /contaniments
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-02-2012, 09:09 PM   #4
cdowns
cdowns's Avatar
would have had better results using lots of laquer thinner again to clean rather than mineral spirits
Old 03-02-2012, 09:32 PM   #5
72farmer
The temp was in the mid 60's and the paint is not old.I used the same can of Rustelom to paint some of my interior metal inside my cab with good results so i think paint is good.When i was wiping down column before sanding w/laquer thinner alot of black paint got on my rag.
Old 03-02-2012, 09:30 PM   #6
black_sheep454
It's caused by a reaction between the two different types of paint. For example if you try to spray base coat/clear coat over enamel that will happen. You can either strip it bare and use whatever paint you want, sand the enamel paint of and try a lauqer paint, or if your lucky sand it down and respray using very light coats. The heavier the coat the worse it will wrinkle.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 03-02-2012, 09:35 PM   #7
LakeAnna
LakeAnna's Avatar
Sand it flat again and prime it with light coats to seal it. Clean it several times with final wash (wax and grease remover). Once it's sealed you should have no more issues.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 03-02-2012, 10:44 PM   #8
72farmer
It just hit me i did not use mineral spirits as a final wipe down.I used rubbing alcohol.
Old 03-02-2012, 09:34 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Mineral spirits has an oily residue.It will always cause fish eyes in my experience.I use paint thinner or brake cleaner and let it dry thoroughly.Mine is finally starting to wear thru after 10 years.Also,watch the humidity.It can cause slow drying at the least and even prevent paint from drying fully.Use a light coat then a heavier cover coat.You can also warm the paint in a contaiiner of hot water(not boiling on the stove) just enough to bring the temp up.Make sure you have temps of at least 50 and below about 85.The humidity levels are on the label.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-02-2012, 11:31 PM   #10
black_sheep454
I just looked closer at your pics and looks more like a fish eye reaction than a wrinkle. As I posted before a wrinkle or raise is a reaction between two materials that dont agree. The wrinkle or raise looks like cracks in the paint. Fish eyes come from contamination from oil. If there is oil anywhere around the area you are painting the oil residue in the air can cause this. I would sand it down and use some heat like a heat gun to try and bake out any oil that may be in the underlying surface. Then you can clean very well with a wax and grease remover. The trick with any cleaner is to wipe it off when it's still wet. If you just take a wet rag with cleaner and wipe over it it will leave the residue on the surface. You want to wipe it down with a wet cleaner rag then wipe that off when it's wet with a dry cloth. Then give it another shot with your paint in a small spot, no need to have to sand the whole thing again if it still has problems.
Old 03-03-2012, 12:01 AM   #11
SactoJim
SactoJim's Avatar
That is contamination for sure. A column that's 40 years old or so has probably seen it's fair share of some type of silicone based detailing products (Armorall) over the years. If that were a reaction to the substrate (old surface), it would have a more "wrinkly" look. Did you start sanding it before you cleaned it real well.....if so, you may have just worked the contaminates into the surface making them even harder to remove. I'd wipe all that paint off with lacquer thinner and prep the surface again. Take a hair dryer and get the column nice and warm (not hot) and start spraying again....light coats.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-03-2012, 12:17 AM   #12
lap15
Always use a good quality Surface Prep (or liquid sandpaper) before painting anything!
lap15 is offline   Reply With Quote
Old 03-03-2012, 12:51 AM   #13
PAWS 72
PAWS 72's Avatar
Get the wd-40 or whatever else stuff like that away from the area where you are painting.
Resand the surface that looks like that and use a good wax and grease remover and you should be ok.
PAWS 72 is offline   Reply With Quote
Old 03-03-2012, 12:29 PM   #14
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Always wipe it down with some kind of paint thinner or spirt bassed product to kill any oily/waxy deposits.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-03-2012, 04:26 PM   #15
Katrina/10
Katrina/10's Avatar
It's almost impossible to get rid of the residue left over from those dash protectants, no matter how much you clean and sand. The only thing I have ever seen that works is fisheye preventer added to paint shot with a spray gun.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-03-2012, 04:49 PM   #16
davepl
davepl's Avatar
I've never used fisheye preventer, but I've had good luck with PPG "Wax and Grease Remover". I don't know what's in it, but its a lot more effective than even straight lacquer thinner. Any autobody supply that carries PPG will have it, and it's worth the trip.
I typically media blast first, though you're supposed to use it before AND after, so you don't just push grease into the metal during blasting. I also use rubber gloves not just to protect me but to prevent getting my own skin oils on the piece once I get to the clean stage.
So, in your case, get it clean first. Then degrease. Then sand it and then degrease it again. And while I can't prove it, a coat of metal primer might help (though your sanding step might make it unnecessary.
I know it sounds like a lot of extra work, but if you think about it, if you got rid of 99% of those blemishes you'd still have a dozen, so its worth the extra dilligence.
davepl is offline   Reply With Quote
Old 03-03-2012, 06:02 PM   #17
cdowns
cdowns's Avatar
you need to remove all that new paint then sand and clean the heck out of it multipule times with wax and grease remover then wash with a very strong soap and water solution then again multipule times with laquer thinner then wax and grease remover blow off with air clean again with wax and grease remover then try again with the paint
