63 Cab on Newer Frame
After I sealed the deal with my friend on buying his long bed 63 chevy truck project, I can't stop thinking about what I'm gonna do. It started off life as a 2wd and we started converting it to a 4x4. The spring and axles are underneath it and that's about as far as we got.
I have an 83 shortbed 4x4 that I'm going to use some parts from it. At first I was thinking about putting the axles and hydroboost on the long bed frame/cab, but then I got to thinking. How hard would it be to put the 63 sheet metal on the 83 frame and then shorten the bed? Shortening the bed would be the hardest part because I've never done body work of any kind before, but I've seen a lot of the posts here where people have made a long bed in to a shortbed. Has anyone ever put a 63 cab on a newer frame? Any tips or suggestions or thoughts would be greatly appreciated. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
60-66 Nut
Re: 63 Cab on Newer Frame
Yep, done that about 20 years ago....on a 2wd though. This probably would look better on a 4wd. I would recommend staying with your original frame though, for the reasons mentioned in the thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
Thanks for the link. From what I've read, that looks like more than I want to take on at the moment. So it looks like I'm keeping it a longbed and updating the running gear. Thanks!!!
