03-03-2012, 05:44 AM | #1 |
Just here to tinker
Dash bezel idea
Hey all, I have been thinking lately that I want to try and find the factory air and vacuum gauges to install in my truck and I was trying to decide if I should ditch the factory clock and just use either the vac or air, but I want to use both. So here is what I came up with:
Not sure if anybody has done this before. What do you guys think? Anybody have an idea how we can mirror image the small gauge holes in real life?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
03-03-2012, 06:33 AM | #2 |
Re: Dash bezel idea
You may be able to cut a donor bezel and flip the gauge pod things and epoxy from the back into ore drilled holes. The brushed alumn plate would prob have to be used to hide the cuts
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-03-2012, 06:49 AM | #3 |
Re: Dash bezel idea
I would replace the factory clock. My clock just started not keeping correct time, although it is still ticking. Then the adjustment stem came out of the clock when I was trying to adjust it. I never look at the clock, and have an aftermarket radio with a clock in it, plus I wear a wris****ch, so I see no need for a clock. I can't find a replacement clock from the online suppliers anyway, so it would have to be professionally rebuilt.
I am going to attempt a custom dash, so I found a already "pre-hacked" radio hole bezel on Ebay for about $40 delivered, so I will see how it works out. There are quite a few used bezels on Ebay. I am planning solid wood cut to fit the top of the dash, and foam and vinyl on the front face of the dash. I am hoping to make custom wood surrounds for the defroster vents using the stock vent grilles, which seems like it is going to be the biggest problem. The stock dash never fit those vent openings very well. the air has a lot of opportunity to seep out around the defroster duct terminations, especially since mine are distorted from the heat. |
03-03-2012, 09:17 AM | #4 |
78K & 79C Jimmys
Re: Dash bezel idea
i don't have a pic of the bezel but my lemans was over there, like the grand prix too
I've wondered if the tach would work.... did this in 91
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-03-2012, 03:00 PM | #5 |
Just here to tinker
Re: Dash bezel idea
I was thinking something like this:
Please forgive my awful paint skills.
03-03-2012, 09:50 PM | #6 |
78K & 79C Jimmys
Re: Dash bezel idea
awful,heck some websites gona be postin that for the next custom mockup/setup lol
thats cool me i moved the radio up there,I have a gap to work on once it warms up I am still considering moving the heater controls down to where the radio was my CB fits nice there
03-04-2012, 12:01 AM | #7 |
Re: Dash bezel idea
You could use a doner panel and glue in the panel with plastic weld from the back (like insidious said) http://www.oreillyauto.com/site/c/de...d=plastic+weld This stuff is amazing. I used it on my fan shroud. Or you could just make the whole thing out of aluminum sheet.
03-04-2012, 01:09 AM | #8 |
Re: Dash bezel idea
What about http://www.classicdash.com/shopping/...ank-Panel.html and drill the holes how you want it?
03-04-2012, 01:13 AM | #9 | |
Just here to tinker
Re: Dash bezel idea
I agree with insidious. I will have to cover up the cut marks with the aluminum plating which is ok since my truck has the brushed aluminum already. I am going to be on the lookout for a donor bezel in the junk yards...
