Old 03-03-2012, 11:59 PM   #1
JON70CST
JON70CST's Avatar
'88 Suburban front end for disc brake conversion in '70 1/2 ton?
Hey,
Just wondering if I can use the front end out of a 1988 burb to bolt up to my '70 pickup so I have frot discs? Is the swap the same as using 73-87 front end parts for the conversion?
JON70CST is offline   Reply With Quote
Old 03-04-2012, 12:57 AM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: '88 Suburban front end for disc brake conversion in '70 1/2 ton?
It should work fine. The Suburban carried the same design to 1991.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-06-2012, 04:16 PM   #3
JON70CST
JON70CST's Avatar
He threw in the steering box, linkages with tie-rods and everything from the 88 burb as well. Will this all bolt up as well, and eliminate the need for me to run a conversion sleeve for the tie-rods etc.? Sorry I'm new to this conversion. My truck already has power steering if that makes a difference?
Old 03-07-2012, 01:33 AM   #4
SCOTI
SCOTI's Avatar
You should be able to swap it all. There is a possibility of slight differences w/the steering box hoses vs earlier trucks (73-80) but it should still work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
