Old 03-04-2012, 09:31 PM   #1
kevinc
kevinc's Avatar
Speedometer
Its may have been discussed before,but I couldn't find anything. I've seen guys add a tachometer, vacuum gage, engine minder, voltmeter, etc to their factory 1964-1966 gauge clusters. Has anyone found a replacement electric speedometer head that could use the factory cluster, but be compatable with a 4L60E?
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 03-04-2012, 09:55 PM   #2
henry3rd
Re: Speedometer
I'm hoping these guys get this figured out.
http://ls1tech.com/forums/conversion...-solution.html
The thread says they are working on a motor that connects to the back of your factory speedometer and turns in relation to the signals the vss outputs.
At least thats what I think it says...
henry3rd is offline   Reply With Quote
Old 03-05-2012, 10:05 AM   #3
ls1nova71
ls1nova71's Avatar
Re: Speedometer
Yes, that's what it says, I've been watching that thread too. It sounds promising.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-05-2012, 11:13 AM   #4
kevinc
kevinc's Avatar
Re: Speedometer
That's along the lines I'm looking for. Just hope its well under $350. Hoping for more like >$150. How about converting over a factory electronic speedo? Anyone tried that?
Old 03-05-2012, 11:23 AM   #5
ls1nova71
ls1nova71's Avatar
Re: Speedometer
They "say" it's supposed to be around $150, time will tell I suppose. As for converting to electric, I have one done for a 67-72, but it's not a plug and play by any means, it takes some fabrication, but can be done. Can't remember though, is a 64-66 speedo round or the long sweep type?
Old 03-05-2012, 01:43 PM   #6
kevinc
kevinc's Avatar
Re: Speedometer
Its a long sweep style. Goes from 0-85 mph and the needle travels what appears to be 90 degrees. I'm wondering if there are any late model speedo's that have approx. those same specs.
Old 03-05-2012, 01:56 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Speedometer
I run a scangauge as a speedo, since I can remove it instantly, and it reads off of the VSS signals at the pcm. Its a nice option until you can find a permanent solution, and it can be set to other gauge functions if you don't need it as a speedo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-05-2012, 07:28 PM   #8
19seventeeCustom
Re: Speedometer
I've been reading the thread on the cluster plug in, they are getting close to finish.
I'm sure he will sell a TON, if they really are only $150.
19seventeeCustom is offline   Reply With Quote
