03-05-2012, 09:35 PM | #1 |
Lowering,wheels and offset questions help
Need some help here fellas. I have installed 3 inch drop spindles on the front of my 69 1/2 ton and 5 inch drop coils in the rear. Will 22 x 9.5 wheels with a 18 offset work with what i have done with the suspension . Thanks for any help
03-05-2012, 10:18 PM | #2 |
67-72 parts collector,…
Re: Lowering,wheels and offset questions help
I would say yes up front.
The 18 mm offset is between a 5-3/4"-6" BS for the 9.5 wide rim. The rear of the truck might need a 1" spacer to bring the wheel out closer to the edge of the outer bedside.
03-05-2012, 10:43 PM | #3 |
Thanks for the help friend
03-06-2012, 05:58 AM | #4 |
A little tool that can help a ton with wheels http://www.summitracing.com/parts/PHP-01201 it will let you test fit any rim and tire combo you can think up.
