05-03-2003, 12:49 PM | #1 |
Front crossmember swap
When swapping a 73-up crossmember into a 69 are the frame widths the same or do you need any type of shim to bolt it in.Thanks for any info biddaboy
05-03-2003, 08:52 PM | #2 |
Project92 SWB stepside
The widths are the same.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
05-03-2003, 08:54 PM | #3 |
There may be a diffrence or two with the way the bolt holes match up. Alot of people say to make sure you get everything from the donor to do this swap.
05-03-2003, 10:33 PM | #4 |
There are only 2 bolt's that need to be a little larger other than that direct bolt in easy 2 do.And yes take everything from the donor
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
05-04-2003, 10:56 AM | #5 |
what would Neal do?
why would you do this?
1968 GMC 910 Long Step 250/3onTree 1969 Chevy C10 longfleet, 350/350 |
05-04-2003, 11:58 AM | #6 |
aka Crusher, Crushergmc
Disc brakes, and cheaper drop spindles amoung others.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
05-05-2003, 07:19 PM | #7 |
Cause its fun too!!
05-06-2003, 12:15 AM | #8 |
Thanks for the info you guys are great .biddaboy
03-31-2004, 12:48 AM | #9 |
And what about if you are going from a '69 leaf spring 4wd blazer to the '73 IFS front subframe? Still only the 2 holes to enlarge?
