03-09-2012, 11:51 AM | #1 |
65 Chevy c10 questions
Im 16 and have some questions and could use some assistance. In the 4 speed top loader on the back of a 292, how do you remove the shifter from the tranny? Me and dad think that we have an idea how but we'd like to hear it from someone who can verify our thought. My other question is, can you use the stock intake for a 292 and still run headers? Anything will be helpful. May post pics of both soon for a visual reference.
03-09-2012, 12:06 PM | #2 |
But Found Her 25yrs Later!
Re: 65 Chevy c10 questions
push down on the cap and turn. I think counter-clockwise.
03-09-2012, 02:11 PM | #3 |
Who Me?
That sounds familiar.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
03-09-2012, 03:20 PM | #4 |
You can use the stock intake, but you have to put a delete plate on the bottom & run either water or exhaust bypass in to heat the intake. The original intake is an integral unit with the exhaust/intake bolted together by three bolts. The exhaust has a spring that opens an internal heat riser that normally heats the intake. Id check with Tom Langdon, he has a web site for inline parts. Check with the inliners forum also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-09-2012, 05:27 PM | #5 |
Thanks for the help i will definitely try that the next time im out there, i will also check about the intake because moneys a little tight and i was dreading having to buy another intake
03-09-2012, 05:49 PM | #6 |
Tom Langdon's has the delete plate for the factory intakes. He acan tell you how to plumb the intake to heat it also. He is a wealth of info on chevy inline 6 engines.
