Roadtrip!
![]() Join Date: Feb 2003
Tach dash questions.
I made a harness to hook up tach dashes to test. The test rig is a 71 with hei. I hooked up a 73 dash and the tach went to zero and stayed there. I also hooked up an 87 dash and it seemed like it was 2,ooo rpms high but it was working. I tried some mid-late 70s ones and all worked fine. Does that mean i have 2 bad tach heads? or is there something different about certain years using the same tach harness? Any insight? Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
78K & 79C Jimmys
Re: Tach dash questions.
i was reading about this repair
http://67-72chevytrucks.com/vboard/s...=503733&page=2 maybe some are for 6 cyl?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Moderator
![]() Join Date: Oct 2008
A 6 cylinder tach should read 25% high on an 8. It may be a I6 tach or it may have a bad resistor in the DIP resistor pack.
Roadtrip!
Thanks for the info. I was wondering if the 73 dashes were better off a coil rather than hei.
Moderator
They both run off the coil - lead. I've looked at the tach signal from HEI and Points with a scope. They were similar. Points make more noise but are the same otherwise.
