Old 03-11-2012, 08:35 PM   #1
Ackattack
Ackattack's Avatar
Head Gasket mishap, need opinion
I'm working on my tbi 350 after a blown head gasket. I chased all of the threads in the block and put on the new head gasket. I set on the head and started putting in the new head bolts. I get through the first two torque passes and on the third pass, one of the bolts starts spinning. Basically I stripped the threads in the block some how.
So I figure my only option is to helicoil the block.
My question is, do I need a new head gasket? I don't know if it being torqued down will effect it sealing up once I get the threads fixed.
Ackattack is offline   Reply With Quote
Old 03-11-2012, 08:57 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Head Gasket mishap, need opinion
I would replace the head gasket it is not worth doing the job another time.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-11-2012, 09:51 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I agree^^
I will ask,did you use a tap to chase the threads?The reason I bring it up is that a tap will recut the threads when used to clean them.It isn't much of a cut(usually) but it can be enough to weaken the threads.A thread cleaner is a much better tool to use.They look like a tap with only 2 flutes and generally wont cut the threads.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-11-2012, 10:05 PM   #4
mud.man.rj
mud.man.rj's Avatar
How is the bolt threads, maybe bolt is screwed up. The head gasket will be fine no heat cycle yet. But sounds like a Helicoil is in order, no fun.
mud.man.rj is offline   Reply With Quote
Old 03-11-2012, 10:09 PM   #5
Ackattack
Ackattack's Avatar
Originally Posted by PanelDeland View Post
I agree^^
Yeah, it was a tap, never knew there was a difference. I'm kinda wondering if maybe this was already helicoiled before. When I was chasing the thread one bolt hold in each side of the block was much more difficult than the rest (which means I may have the same issue on the other side.
Old 03-11-2012, 10:15 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
i ran into the same problem on my wife's 67 while building the motor (350) the last outer bolt stripped on me i helicoiled it and reused the gasket no problems out of it.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-11-2012, 11:34 PM   #7
Meatman
Meatman's Avatar
Man I think that truck hates you. I would agree it would probably be best to just buy another head gasket. Sure enough the sob would leak again on ya.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
