Old 03-12-2012, 06:55 PM   #1
dennislbrooks
dennislbrooks's Avatar
1967 4wd shift pattern sticker
Does anyone know the correct location for the 4wd shift pattern sticker for a 1967 K10. I questioned the vendor from whom I bought the shift pattern sticker and all they could say is the driver's compartment. Does it go on top of the driver or passenger visor or in the glove box, or where?
If placed on the ceiling it kinda reads backwards.
dennislbrooks is offline   Reply With Quote
Old 03-12-2012, 11:16 PM   #2
BlackhillsHD
BlackhillsHD's Avatar
Re: 1967 4wd shift pattern sticker
The one on my moms '70 CST Blazer is on the LH of the glove box door. I could get some measurements tomorrow.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 03-13-2012, 06:40 AM   #3
dennislbrooks
BlackhillsHD, I take you mean on the LH side on the outside of the glovebox door?
Old 03-13-2012, 07:27 AM   #4
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
I might be wrong, but i think on the 67-68's it was on the roof above the rear view mirror. I know ive seen some up there but not really sure what years. I think 69-70 had them on the glove box door, and 71-72 didnt have them at all. Then again i could be wrong
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 03-13-2012, 08:11 AM   #5
dennislbrooks
My truck is a custom with the black texture like on the glove box door so not a good place to put it. I am running the correct patterned Ford shifter knob.
If the sticker were reversed it would read correct on the ceiling.
Reads
2H
4H
N
4L
with 2H with stick towards engine. I have tried to find any brochures and searched the web to find where the factory placed. I appreciate everyones responses.
Old 03-17-2012, 01:07 PM   #6
CG
BlahBlahBlah
Reads
2H
4H
N
4L
Man that is a clean looking set up you have there. Nicely done!
Old 03-13-2012, 11:26 AM   #7
1972RedNeck
1972RedNeck's Avatar
Is that a ford shifter stick in there?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 03-13-2012, 01:57 PM   #8
dennislbrooks
not the stick, it is homemade but the knob is ford.
Old 03-13-2012, 09:57 PM   #9
BlackhillsHD
Yeah the Blazer is on the LH outside of the glove box door. Doesn't really look like an option for you though.
Old 03-13-2012, 11:06 PM   #10
odog
odog's Avatar
I believe in 67 the sticker is on the passenger side of the cab, between the rearview mirror and the passenger visor, if it has one. On the 67 cab I have it doesnt have a passenger visor, but the sticker is there, not sure of measurements though....
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 03-15-2012, 05:17 PM   #11
vectorit
What?
vectorit's Avatar
Here is a photo of a 1967 K10 Suburban xfer case shift pattern sticker.
This is from a un restored burb.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-16-2012, 09:43 AM   #12
martindc1
Transfer case shift pattern is the ceiling above the mirror. Lockout hub sticker goes on the left side of the glove box door.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 03-16-2012, 11:20 AM   #13
dennislbrooks
thanks guys, for a 67, I will go with the last 2 posts and others above
Old 03-18-2012, 09:34 AM   #14
martindc1
Here you go...
Old 06-16-2012, 08:33 PM   #15
amccomb
I need to get that sticker for my 66 k10, what vendor did you get it from?
amccomb is offline   Reply With Quote
Old 06-16-2012, 10:29 PM   #16
Monty
Brothers has 'em
http://www.brotherstrucks.com/products.asp?dept=434
Monty is offline   Reply With Quote
