Old 03-12-2012, 11:17 PM   #1
Number21
Number21's Avatar
Removing a stuck canopy?
My truck has a canopy on the back that I was hoping to take off today. I took off all the clamps inside but it is still stuck solid by the foam rubber tape/sealant between the bed rails and the canopy.
Anybody have any thoughts on how I can get this off without totally ruining the bed?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 03-12-2012, 11:53 PM   #2
MilkyJoe
MilkyJoe's Avatar
Re: Removing a stuck canopy?
get a thin knife with a good edge and run it across the entire rim of the canopy.
Should do the trick
I did this when I picked up a canopy from a ford ranger and it had that foam strip AND screws lol. no clamps
MilkyJoe is offline   Reply With Quote
Old 03-13-2012, 12:01 AM   #3
71swb4x4
71swb4x4's Avatar
Take it down some old mountain trails at 50mph, it should fall off on it's own...
Do you have a helper? Maybe some piano wire wrapped around some dowels for handles with one of you inside and one outside.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-13-2012, 12:09 AM   #4
MilkyJoe
MilkyJoe's Avatar
X2 on the piano wire, just like when you take out a windshield
Old 03-13-2012, 12:42 AM   #5
Eyegore
What Hump?
Eyegore's Avatar
Use a hot air dyer and slowly pry it up or wait until August and bring it to phoenix when its a 118 out, it'll come off.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-13-2012, 12:52 AM   #6
cory d
cory d's Avatar
my buddy got a truck with a canopy sealed on. we both had to crawl inside and and push up for the foam tape to let go
cory d is offline   Reply With Quote
Old 03-13-2012, 01:20 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Happened on a friend of mines truck. Since canopying grow on trees we roped it and yanked it off with another truck came out in peices. Prev owner had used rtv on everything
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-13-2012, 01:35 AM   #8
jhngardner367
jhngardner367's Avatar
Get some mineral spirits,at the hardware store.Use a paintbrush,and paint it on the tape.Get it soaked in good,then wait 10-15 minutes,and start peeling it off.
The mineral spirits won't hurt the paint/canopy,and it washes off easily(it's also good for oil stains on the concrete).You may have to soak it a couple of times,but usually once does it.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-13-2012, 10:31 AM   #9
TDS-MN
I'll agree, it could still just be the tape holding it on. That stuff can really grab over time. I struggled with mine a bit after removing the clamps, but it finally did lift away.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
